MWarren3549 Posted September 29, 2022 Share Posted September 29, 2022 Do either of these items work? Do the help save gas, get more mileage per tank? Are they safe? ANY input/suggestion/knowledge on this would be greatly appreciated. I have had my 2015 Subaru Legacy for just over a year. Knock on wood ... it has been running great. I thought maybe these additives might help. THX! Link to comment Share on other sites More sharing options...
BoozeRS05 Posted September 30, 2022 Share Posted September 30, 2022 I can’t remember who recommended it, someone on the forum here, but Berryman’s B12 is the fuel system cleaner I use. I dump in half a can before filling up, probably once every 3k miles or so on both my cars. Use a bit of it to start my John Deere every spring too. Whether it actually helps I can’t make any claims, but I get pretty damn good MPG in both my cars and my LGT fuel trims are usually in fine shape. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
MWarren3549 Posted September 30, 2022 Author Share Posted September 30, 2022 11 minutes ago, BoozeRS05 said: I can’t remember who recommended it, someone on the forum here, but Berryman’s B12 is the fuel system cleaner I use. I dump in half a can before filling up, probably once every 3k miles or so on both my cars. Use a bit of it to start my John Deere every spring too. Whether it actually helps I can’t make any claims, but I get pretty damn good MPG in both my cars and my LGT fuel trims are usually in fine shape. Oohhh Thank you. If I get some MPG benefit - great. It's a cheap try. And as long as I don't 'hurt/harm' anything, I'm happy. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 1, 2022 Share Posted October 1, 2022 Yes, I also use Berryman B12 after reading about it from someone on here many years ago. Walmart has it for under $4.00 a can. Used to be around $2.50. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted October 6, 2022 Share Posted October 6, 2022 (edited) Good ol B12. Been using it since I was in high school. Even my grandfather used it. LOL. You can use it to clean engine sludge too. Edited October 6, 2022 by m sprank Link to comment Share on other sites More sharing options...
