ntadime Posted December 12, 2005 Share Posted December 12, 2005 Anyone have a squeek at the end of the travel of there clutch?I tried lubricating it with spray (WD40 type) but didn't change it. Link to comment Share on other sites More sharing options...
rallispec Posted December 12, 2005 Share Posted December 12, 2005 just pretends it's your blow off valve. to answer your question, yes, several people have complained about it. I'm not sure what the best resolution is though. perhaps you should search on 'clutch squeak' Link to comment Share on other sites More sharing options...
LotusSeven Posted December 12, 2005 Share Posted December 12, 2005 Same here, but so far only when the car is cold. It tends to go away once the car is fully warmed up. I think it's coming from the clutch master cylinder, not the linkage. Heavy Metal Killed Beethoven Support Classical Music Link to comment Share on other sites More sharing options...
Xenonk Posted December 12, 2005 Share Posted December 12, 2005 silicone spray the parts. Keefe Link to comment Share on other sites More sharing options...
RochNY91TSI Posted December 12, 2005 Share Posted December 12, 2005 I've got the problem too and it does seem to go away when the car is warm (that or I've got my music too loud to hear it ) Link to comment Share on other sites More sharing options...
mccorry Posted December 12, 2005 Share Posted December 12, 2005 I have the squeek too..... Link to comment Share on other sites More sharing options...
IAHAWK Posted December 12, 2005 Share Posted December 12, 2005 Me too... Link to comment Share on other sites More sharing options...
emorphien Posted December 12, 2005 Share Posted December 12, 2005 Same here, I couldn't tell where the squeaky joint was though on a quick inspection. Link to comment Share on other sites More sharing options...
nyc lgt Posted December 12, 2005 Share Posted December 12, 2005 I too have the squeak - both me and the clutch on my LGT. What are the parts that I should spray with silicone? Is this an "under the car" or "inside the engine compartment" thing? Link to comment Share on other sites More sharing options...
emorphien Posted December 12, 2005 Share Posted December 12, 2005 I think it's above the plastic panel above your feet. Link to comment Share on other sites More sharing options...
iceman Posted December 12, 2005 Share Posted December 12, 2005 Next time you're at the dealer, have them take a look at it...I thought it was going to be something worse, but thye lubed it an no more squeek. If only they could do something about the clutch chatter in 1st... Goin' to Carolina in my mind...and in my car on the 16th! Link to comment Share on other sites More sharing options...
sleepin gt Posted December 12, 2005 Share Posted December 12, 2005 i had the same thing. the clutch is attached to a poll that runs as a pivot point for the other 2 pedals. My squeak was beind the gas pedal (yet still enduced by pushing the clutch) Take some stuff apart and lube Link to comment Share on other sites More sharing options...
kanoswrx Posted December 12, 2005 Share Posted December 12, 2005 I have the squeak as well, have had it pretty much the whole life of the car. My WRX had it too. It's really only when it's cold out, much more noticeable now that its winter. I will try some silicone lubricant I think when I get a chance. Now if I could just get my front suspension to stop squeaking and making noises when going over bumps in the road. Link to comment Share on other sites More sharing options...
tsyGT Posted December 12, 2005 Share Posted December 12, 2005 I have the same squeak periodically when it's cold. But I think mine's coming from my seat, not the pedal. I'm going to have my dealer tighten my seat down the next time I go in. tom tom Link to comment Share on other sites More sharing options...
emorphien Posted December 12, 2005 Share Posted December 12, 2005 You can tell if it's the pedal by pushing the pedal with your hand. It's easily overpowered by open windows or the radio but it is annoying. Link to comment Share on other sites More sharing options...
starlabs Posted December 12, 2005 Share Posted December 12, 2005 I've had it too.. but it seems to come and go. When I first got the car it was rather loud and annoying. But now, about 5-6 months later I don't notice it at all. I did try spraying some WD40 on it some time back, but that didn't seem to help at the time. -=- Livin life at 140 BPM -=- Link to comment Share on other sites More sharing options...
elpete77 Posted December 12, 2005 Share Posted December 12, 2005 Everyone listen . . . I have the answer!!!!! I had the same problem, and the dealer replaced some switch in the clutch pedal , and it's gone!!!! Under warranty. Whooot! So tell your delaer service people to replace that switch for free!!! Link to comment Share on other sites More sharing options...
