MiikaS Posted September 5, 2022 Share Posted September 5, 2022 (edited) Hi all Suby folks! I have started to develop a new software to tune, log and flash Subaru ECUs. This project started an idea about year ago, to combine Subaru tuning support to my own standalone engine management system software, called FastECU. Time passed by and finally this summer I got a little kick to the project when user [b]rimwall[/b] in RomRaider forum started project to mod [b]NisProg[/b] opensource kernels to suit flashing Subaru ECUs with NisProg software. We put a little effort together and opensourced JDM Forester XT/Cross Sports ECUs to flashable! I call this fxt02 flashmethod for now on. After that I decided that now is the time to start my tuning software project, as NisProg is command line tool, RomRaider does not support flashing (latest supports CAN-only ECU flashing via command line) and EcuFlash does not support all ECUs and is missing logging ability and is most likely also out of development. So, for now after few weeks of combining codes I have software which almost fully supports RomRaider editor definitions (support for nested base/inherit defs not yet added) and is able to open, tune and save HC16/SH7055/SH7058 ROMs (DTC disable option still missing, but coming soon). This software is written with Qt 5.12.8 and it will work atleast on Windows 7+, both 32bit and 64bit and on Linux 64bit platforms. Possible to get working on Macs too but can't test it myself as I have only Linux and Windows machines. From NisProg I use modified opensource kernels and some snippets of code that are related to kernel read/compare/write ability. So next steps are (not exactly in this order): - Adding sti04 (SH7055) flashmethod and open port 2.0 support (these I am doing now) - Adding sti05 (SH7058) flashmethod - Adding wrx02/wrx04/fxt02 flashmethods - Adding CAN flashmethod - Adding Diesel ROM support - Adding other Subaru ECUs (JECS/Hitachi etc.) - Adding logging support - Adding EcuFlash definition support - Adding Nissan ECUs support - Maybe other make/models too I will release software for test use as soon as I have few flashmethods added and tested. This will be opensource software (under GPLv3), so source code will also be released after I have cleaned all unnecessary code from it (mostly my standalone ems code that has no use in it). I also have my own forum for this project, found here --> https://www.syvanenmotorsport.fi/forum/index.php, that is meant to be the "base" for discussing of all things related to this software. There is already software to download to read and flash JDM Forester XT/Cross Sports ECUs. Note that this ECU is possible read and write only in car for now, haven't figured out yet what connections it needs to able to do it on bench. This software will also support basic K-Line cables, so no need for Open Port 2.0 cable if there is no need to pulse 'Line End Check 2' -pin, that is needed for wrx02/fxt02 methods. I have myself used basic K-Line cable on fxt02 method development, I just soldered wire from FTDI-chip DTR-pin to pin9 (in Subaru FSM this pin is noted as pin8) on OBD-connector so no need for Open Port 2.0 at all. - Miika Syvänen Edited September 9, 2022 by MiikaS 3 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 6, 2022 Share Posted September 6, 2022 Subscribed! Good to see there are still some people out there interested in possibly improving the tuning/logging experience for the Subie crowd. Link to comment Share on other sites More sharing options...
MiikaS Posted September 24, 2022 Author Share Posted September 24, 2022 Sti04 flashing method is working with generic K-Line OBD adapter and OP2 in both Windows and Linux. Next I need to add logging support atleast some level and test that wrx02 and fxt02 methods are fully working and then it's time to publish first test version. 2 Link to comment Share on other sites More sharing options...
NORULZleggy Posted October 19, 2022 Share Posted October 19, 2022 This is great, the AP3 still can be tuned even with the stuff cobb has done. Just got mine done 2 weeks ago. Car is solid. Link to comment Share on other sites More sharing options...
MiikaS Posted November 10, 2022 Author Share Posted November 10, 2022 (edited) https://www.syvanenmotorsport.fi/forum/index.php?topic=15.0 Some updates, software is on github now. There is precompiled files for Win7+ and Linux. If someone is testing this, please comment all bugs/issues/etc. on my linked forum. It's still very badly in progress due to little time between work and family and like to hear from people how they wan't different things to work. Edited November 10, 2022 by MiikaS 1 Link to comment Share on other sites More sharing options...
MiikaS Posted November 21, 2022 Author Share Posted November 21, 2022 More updates to software: https://www.syvanenmotorsport.fi/forum/index.php?topic=15.msg32#msg32https://github.com/miikasyvanen/fastecu-oem Link to comment Share on other sites More sharing options...
MiikaS Posted November 29, 2022 Author Share Posted November 29, 2022 Another update with EcuFlash definition support and some bugfixes https://www.syvanenmotorsport.fi/forum/index.php?topic=15.msg16#msg16 1 Link to comment Share on other sites More sharing options...
MiikaS Posted December 10, 2022 Author Share Posted December 10, 2022 Some bugfixes and sti05 flashmethod confirmed. https://www.syvanenmotorsport.fi/forum/index.php?topic=15.msg16#msg16 2 Link to comment Share on other sites More sharing options...
tysparks81 Posted November 7, 2023 Share Posted November 7, 2023 Interested to see how this is coming along. Curious about how you are handling ecutek & cobb tunes vs OEM basemaps. 1 #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
