2012 Legacy H6 Posted July 27, 2022 Share Posted July 27, 2022 Suddenly my radio quit on me. The only button that responds on the radio is Display to turn off the screen. CD player doesn't work either and wont accept any CD being inserted. Steering wheel buttons dont work to control the radio as well. Fuses were checked but no issues. Help please. Link to comment Share on other sites More sharing options...
DrD123 Posted July 28, 2022 Share Posted July 28, 2022 there are usually a bunch of them on eBay in the 50-70 range - I'd just swap it out, or use it as a chance to upgrade to something fancy Link to comment Share on other sites More sharing options...
FLlegacy Posted July 30, 2022 Share Posted July 30, 2022 (edited) Which radio do you have? A used replacement, if it's an oem unit, would be the simplest solution. Edited July 30, 2022 by FLlegacy Link to comment Share on other sites More sharing options...
2012 Legacy H6 Posted July 30, 2022 Author Share Posted July 30, 2022 (edited) 7 hours ago, FLlegacy said: Which radio do you have? A used replacement, if it's an oem unit, would be the simplest solution. It's the oem radio with navigation and DVD player. Do I have to purchase the nav too? That's gonna cost a lot more. Edited July 30, 2022 by 2012 Legacy H6 Link to comment Share on other sites More sharing options...
FLlegacy Posted July 30, 2022 Share Posted July 30, 2022 I don't think you need the navigation module just the head unit. Make sure you match the model number on the head unit exactly. Link to comment Share on other sites More sharing options...
2012 Legacy H6 Posted July 31, 2022 Author Share Posted July 31, 2022 14 hours ago, FLlegacy said: I don't think you need the navigation module just the head unit. Make sure you match the model number on the head unit exactly. I can't find the radio head unit without the Nav screen attached. I dont believe they are separate. Link to comment Share on other sites More sharing options...
FLlegacy Posted July 31, 2022 Share Posted July 31, 2022 The screen is definitely part of the headunit, I was talking about the navigation module on some Subaru models that is a separate system. It may be integrated in the legacy. Link to comment Share on other sites More sharing options...
2012 Legacy H6 Posted July 31, 2022 Author Share Posted July 31, 2022 This has been resolved. The simplest, quickest fix for this issue of the stereo not functioning at all was to remove the DVD plastic tab, insert a hairpin or paperclip in to the hole above CD where the Reset button is, hold for a moment and the entire system will reset, bringing back to life the entire audio system. I give credit to the Subaruoutback.org forum. 1 3 Link to comment Share on other sites More sharing options...
JT_36R Posted February 6, 2023 Share Posted February 6, 2023 Thanks for posting here. Buttons were non-responive for me, but the reset worked for me. Link to comment Share on other sites More sharing options...
