Przemek Posted June 14, 2022 Share Posted June 14, 2022 I dont have a lift but Im thinking its rack and pinion. Going on saturday to the dealer to have them check it. Any idea how much it will cost? 2018 Legacy with 22k miles Link to comment Share on other sites More sharing options...
ammcinnis Posted June 14, 2022 Share Posted June 14, 2022 (edited) See TSB 04-17-17R. Replacing the rack's tension spring is something that a lot of people have done themselves; it's cheap and relatively easy. It does require a special tool, though.TSB_04-14-17R_pp1-4.pdf Edited June 15, 2022 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Przemek Posted June 15, 2022 Author Share Posted June 15, 2022 (edited) See TSB 04-17-17R. Replacing the rack's tension spring is something that a lot of people have done themselves; it's cheap and relatively easy. It does require a special tool, though. Thank you In case this comes up in your search, dealership quoted me $890. Edited June 20, 2022 by Przemek Link to comment Share on other sites More sharing options...
St8-e Posted June 30, 2022 Share Posted June 30, 2022 See TSB 04-17-17R. Replacing the rack's tension spring is something that a lot of people have done themselves; it's cheap and relatively easy. It does require a special tool, though. Not trying to jack this thread, but after reading the TSB, does this special bit used to remove the screw come with the spring kit (part # referenced in the TSB)? Assuming this has to be ordered from A dealer? Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
ammcinnis Posted June 30, 2022 Share Posted June 30, 2022 ... does this special bit used to remove the screw come with the spring kit (part # referenced in the TSB)? No, you have to buy it separately; even the dealers have to buy it separately. As the TSB indicates on page 1, the correct BTP40P Torx bit is available from Bosch or Matco. Some owners have also reported finding the proper tool (at lower cost) on Amazon or eBay. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
d0bdish18 Posted June 30, 2022 Share Posted June 30, 2022 I replaced the same piece a few months ago and used this: Sent from my Pixel 6 using Tapatalk Link to comment Share on other sites More sharing options...
Przemek Posted July 15, 2022 Author Share Posted July 15, 2022 After I came back from the dealership all was good for about two weeks but now it came back. It seems to do it only when I'm breaking though. But the sound is the same. I have to go there again, hopefully it just needs an adjustment Link to comment Share on other sites More sharing options...
