RumblyXT Posted May 13, 2022 Share Posted May 13, 2022 (edited) So instead of creating a thread for every question about weird/odd noises, I decided to create this one. Being that my ‘05 OBXT has over 214K miles, there’s a few things I’d like to ask about to those of you mechanical/suspension/transmission gurus. Hopefully this thread will serve the purpose for those looking to solve those puzzling clunks, pops, grinding, hissing, etc noises.. I’ll start with a couple of mine.. 1. Sometimes right after starting my car, it makes this hissing/grinding kinda noise and then it goes away.. Could this be a bad starter motor? 2. When driving, right in between braking and accelerating, I can hear a very subtle “cluck” type noise.. any ideas? Please feel free to post/comment your helpful ideas on what could be. Edited May 13, 2022 by RumblyXT Link to comment Share on other sites More sharing options...
Max Capacity Posted May 13, 2022 Share Posted May 13, 2022 (edited) 1. If that goes away a couple of seconds after the key is in "run" then yes, most likely the starter. There is a DIY on here for that. 2. grab your drive shaft, "propeller shaft" as Subaru calls it and see if there's play near the carrier bearing. I seem to recall replacing my shaft about that mileage. HERE's where I got my shaft from, https://driveshaftstore.com/Subaru-Legacy-Driveshaft-2005 Edited May 14, 2022 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RumblyXT Posted May 13, 2022 Author Share Posted May 13, 2022 1. Yes, the noise lasts 1-2 seconds. Good to know, simpler fix than #2. 2. So the drive shaft.. that makes sense for it to be that noise. Thank you Max Capacity Link to comment Share on other sites More sharing options...
RumblyXT Posted May 13, 2022 Author Share Posted May 13, 2022 (edited) Since we’re at it, here’s a few more.. 3. Right after filling up, the car has difficulty starting. I have to step on/hit the gas pedal a few times, then it will start. I researched this one, seems it could be the Vapor Canister Purge Valve. 4. Sometimes while backing up slowly and slightly turning the wheel left or right, the car simply shuts off, it’s done it a few times. 5. When making close left/U turns, there’s this grinding noise, best way I can describe it is like dragging a metal pipe on the floor/cement. Steering rack? 6. And finally, when making wide left turn, there’s clicking/clucking noises. Feels like it’s coming from the front left wheel. Left CV axle going bad? Yeah, I got my work cut out for with this car Not to mention it’s slight overheating issue lol I’ve come to think it’s either a bad thermostat or a clogged radiator. Already working on that. Edited May 13, 2022 by RumblyXT Link to comment Share on other sites More sharing options...
Pleides Posted May 14, 2022 Share Posted May 14, 2022 My driveshaft has made that noise forever. I should get around to fixing it.... Link to comment Share on other sites More sharing options...
Max Capacity Posted May 14, 2022 Share Posted May 14, 2022 The starter DIY, https://legacygt.com/forums/showthread.php/diy-starter-repair-remove-disassemble-grease-reinstall-w-pics-218329.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RumblyXT Posted May 14, 2022 Author Share Posted May 14, 2022 Thanks again Max Capacity. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 14, 2022 Share Posted May 14, 2022 Thanks again Max Capacity. Your very welcome. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pleides Posted May 14, 2022 Share Posted May 14, 2022 My handbrake button rattles like crazy and I'm not ingenious enough to devise a fix for it. Might just shove some thin cotton or something there to make it stop as it drives me crazy. Also get wind noise from both the seal around the B-pillar/side window trim. Link to comment Share on other sites More sharing options...
RumblyXT Posted May 15, 2022 Author Share Posted May 15, 2022 ^^You might need to replace the window gussets, that's the noise comes to these cars at higher speeds. It happens after prolonged use of opening and closing the doors holding them by the glass. I'm interesting on what the handbrake rattle could be. My handbrake leather wrap came off.. lol my car is falling apart. Do you guys just use crazy glue for this? Link to comment Share on other sites More sharing options...
Pleides Posted May 16, 2022 Share Posted May 16, 2022 ^^You might need to replace the window gussets, that's the noise comes to these cars at higher speeds. It happens after prolonged use of opening and closing the doors holding them by the glass. I'm interesting on what the handbrake rattle could be. My handbrake leather wrap came off.. lol my car is falling apart. Do you guys just use crazy glue for this? Already replaced one of the seals - the driver's side one. That made the noise mostly go away in the sense that I can just roll the window down briefly when on the freeway and back up and it's gone. Noise level in general is down. The gussets probably do need to be replaced though, yeah. And yes, gorilla glue or whatever and you're golden on the parking brake. Link to comment Share on other sites More sharing options...
RumblyXT Posted May 17, 2022 Author Share Posted May 17, 2022 Any thoughts on what these could be? 3. Right after filling up, the car has difficulty starting. I have to step on/hit the gas pedal a few times, then it will start. Vapor Canister Purge Valve? 4. Sometimes while backing up slowly and slightly turning the wheel left or right, the car simply shuts off, it’s done it a few times. 5. When making close left/U turns, there’s this grinding noise, best way I can describe it is like dragging a metal pipe on the floor/cement. Steering rack? 6. And finally, when making wide left turn, there’s clicking/clucking noises. Feels like it’s coming from the front left wheel. Left CV axle going bad? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 17, 2022 Share Posted May 17, 2022 3. I think that's the cause, there was a thread here years about that issue. google the problem. 4. sorry, I recall my wagon doing that, once or twice, back about late 2009, I didn't fix anything, hasn't done it since. 5 &6, I would check that left CV axle. clicking noise is a CV joint going bad. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
