speculaas Posted April 18, 2022 Share Posted April 18, 2022 A few years back the fuel pump in my '03 Legacy failed while on a trip and that was a problem I won't let happen again. My question is, as I was looking at RockAuto site today, they show 3 or 4 different in-line fuel filters for my current 2015 Legacy. I thought all the fuel filters were now inside the fuel tanks? Does the '15 Legacy have a fuel filter somewhere under the hood? '15 Legacy Premium 4 cyl 154,000 miles Link to comment Share on other sites More sharing options...
ammcinnis Posted April 18, 2022 Share Posted April 18, 2022 (edited) I thought all the fuel filters were now inside the fuel tanks? Does the '15 Legacy have a fuel filter somewhere under the hood? The OE fuel filter for all Gen 6 Legacys (and Gen 5 Outbacks) is mounted in the tank, as part of the fuel pump assembly. There is no external, in-line fuel filter. Fuel pump failure in these cars seems to be extremely rare. Maintenance is at your discretion, but IMO the filter should not require routine replacement as long as you're buying good-quality, name-brand fuel from moderate to high volume stations. Seller participation in the "Top Tier" program is probably a plus. Edited April 18, 2022 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
silverton Posted April 18, 2022 Share Posted April 18, 2022 the only time your pump should fail is if you regularly have less than 1/4 tank of gas. Link to comment Share on other sites More sharing options...
Brisvegas Posted April 19, 2022 Share Posted April 19, 2022 the only time your pump should fail is if you regularly have less than 1/4 tank of gas. I don't think 1/4 tank will cause any problems .... running consistently on "empty" on the other hand, might be another story. Link to comment Share on other sites More sharing options...
ammcinnis Posted April 19, 2022 Share Posted April 19, 2022 (edited) the only time your pump should fail is if you regularly have less than 1/4 tank of gas. This is a persistent myth ... persistent but untrue. An in-tank pump is cooled (and lubricated) by the fuel flowing through it, not by the fuel surrounding it. It has been this way since at least the 1980s. See attachment. Edited April 21, 2022 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
speculaas Posted April 19, 2022 Author Share Posted April 19, 2022 Thanks to all for the information. Link to comment Share on other sites More sharing options...
