1-3-2-4 Posted April 8, 2022 Share Posted April 8, 2022 I’ve had this on my LGT but this happened on my wife’s car so it won’t open from the outside but will open from the inside.. however she put the child lock on and now can’t get the door open at all.. is all hope lost? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 8, 2022 Share Posted April 8, 2022 It MAY be possible to remove the door panel from the inside? It will probably be a pain, but worth trying. Link to comment Share on other sites More sharing options...
tehspud Posted April 8, 2022 Share Posted April 8, 2022 Check out posts 5 & 6 from this. Looks like your best bet is using a thin flexible piece of metal or plastic to push the child lock back to "free" from the inside. https://www.subaruoutback.org/threads/2005-outback-rear-passenger-door-mechanism-snapped-child-lock-engaged.96362/ Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 8, 2022 Share Posted April 8, 2022 Yeah, looks like it is going to work. Very nice. Link to comment Share on other sites More sharing options...
Pleides Posted April 9, 2022 Share Posted April 9, 2022 I'm no genius but having replaced the door lock actuator back there, I'm pretty sure you could have plenty of access to take the door apart if you took the seat bottoms out. Could be wrong. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 17, 2022 Author Share Posted April 17, 2022 Finally got it fixed but what is the reason why I can't open the door from the outside but the inside it works fine? Link to comment Share on other sites More sharing options...
Pleides Posted April 17, 2022 Share Posted April 17, 2022 If you take apart the door you'll see how the latch mechanism works. The exterior door handle mechanism on your car either disconnected or broke. Pretty common problem on these cars. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 21, 2022 Author Share Posted April 21, 2022 Yeah I tried to take the door card off but for some reason I had a hard time trying to finally get it off something near the inside door latch. Link to comment Share on other sites More sharing options...
58Tucker Posted April 23, 2022 Share Posted April 23, 2022 I should have taken pictures when I fixed mine. Rear driver side door. Once I got the child lock undone with a flexible piece of plastic sheet, I found that the exterior latch had a lever broken off. It was easy to see where it was broken. After drilling and pinning the broken lever for mechanical support, I used some Quickseal Metal Reppair epoxy to form the lever back to the broken area. The shape is the duplicated on opposite end of the handle, so you know what it is supposed to look like. I did all that 'cause I'm cheap, had the time, and the stuff on hand. Of course it would have been easier to install a new handle. $40 on ebay. Works great now, and I dare say that with the pinned reinforcement, stronger than new. Link to comment Share on other sites More sharing options...
