thecoolmankyle Posted March 6, 2022 Share Posted March 6, 2022 (edited) SOLD SOLD SOLD Year, Make and Model: 2005 legacy GT wagon Color: White Miles: 194,000 Transmission: manual Title: clean Lien: none Location: Morganton NC VIN: 4S3BP686656372365 Seller's email address: 05.fang_waters@icloud.com Asking Price: $10,500 05 lgt wagon 5speed Limited interior Body has 194k Engine has 22k on it and was built at a local performance shop where it was was blueprinted and balanced. Turbo was replaced at the same time as the engine. Jdm power folding heated mirrors that work like factory. jdm grill, jdm rear lights Led fog and high beam lights Hid low beam lights All interior lights are led. Painted trim on tailgate Aftermarket radio with backup camera and headrest monitors. 10 sundown sub in custom leather wrapped box in back. Weather tech floor mats. The car has zero rust! Perrin catless up pipe IAG oil lines and banjo filters removed kyb struts with Tein S.tech springs Megan racing rear adjustable camber kit Perrin turbo heat shield EXEDY Racing Lightweight Flywheel EXEDY stage 2 clutch Front control arm bushings were recently replace with polyurethane bushings The shifter was replaced with a short throw, and the bushings for the shifter were also replaced with polyurethane bushings Muffler delete Tvg delete All New injectors. Cobb access port Cobb cold air intake Turbo xs blow off valve Off the line performance coil packs Stop tech pds and slotted rotors Sti fuel pressure regulator mod Sti aluminum pedals Pro tuned by CryTune Comes with a ton more that’s not on it yet. Cobb down pipe Cobb boost controller IAG air oil separator. Boost, oil pressure and wide band pro sport gauges Custom gauge pod for the cubby above the radio. All factory stuff like the grill any anything else I’ve changed. Asking $10,500 Edited March 12, 2022 by thecoolmankyle Sold Link to comment Share on other sites More sharing options...
s2baru Posted March 9, 2022 Share Posted March 9, 2022 Does look nice.Not to nitpick, Looking kinda wet underneath there...due for valve covers to be done or a reseal on an oil pan? Link to comment Share on other sites More sharing options...
thecoolmankyle Posted March 12, 2022 Author Share Posted March 12, 2022 And now she is gone! SOLD Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
