Morganton NC - 2005 Legacy GT Wagon 5speed
thecoolmankyle
SOLD SOLD SOLD
Year, Make and Model: 2005 legacy GT wagon
Color: White
Miles: 194,000
Transmission: manual
Title: clean
Lien: none
VIN: 4S3BP686656372365
Seller's email address: 05.fang_waters@icloud.com
Asking Price: $10,500
05 lgt wagon 5speed
Limited interior
Body has 194k
Engine has 22k on it and was built at a local performance shop where it was was blueprinted and balanced.
Turbo was replaced at the same time as the engine.
Jdm power folding heated mirrors that work like factory.
jdm grill, jdm rear lights
Led fog and high beam lights
Hid low beam lights
All interior lights are led.
Painted trim on tailgate
Aftermarket radio with backup camera and headrest monitors.
10 sundown sub in custom leather wrapped box in back.
Weather tech floor mats.
The car has zero rust!
Perrin catless up pipe
IAG oil lines and banjo filters removed
kyb struts with Tein S.tech springs
Megan racing rear adjustable camber kit
Perrin turbo heat shield
EXEDY Racing Lightweight Flywheel
EXEDY stage 2 clutch
Front control arm bushings were recently replace with polyurethane bushings
The shifter was replaced with a short throw, and the bushings for the shifter were also replaced with polyurethane bushings
Muffler delete
Tvg delete
All New injectors.
Cobb access port
Cobb cold air intake
Turbo xs blow off valve
Off the line performance coil packs
Stop tech pds and slotted rotors
Sti fuel pressure regulator mod
Sti aluminum pedals
Pro tuned by CryTune
Comes with a ton more that’s not on it yet.
Cobb down pipe
Cobb boost controller
IAG air oil separator.
Boost, oil pressure and wide band pro sport gauges
Custom gauge pod for the cubby above the radio.
All factory stuff like the grill any anything else I’ve changed.
Asking $10,500
Edited by thecoolmankyle
Sold
