bcrosby51 Posted February 25, 2022 Share Posted February 25, 2022 So, new to me 15 Legacy Limited, 106,000 miles. First snow drive in it last night. Was on the highway and 2 times, it felt like the brake was tapped, like just a quick grab, and then it was fine. I thought it might have been from the snow. Today on the way to work, roads were clear, about 15 miles into my drive, it did it again. Only once. Is this a CVT issue? Its just a split second, but it feels like you just tapped the brake pedal, then its fine. Link to comment Share on other sites More sharing options...
ronemus Posted February 25, 2022 Share Posted February 25, 2022 Do you have EyeSight? If so, it probably had a hiccup - it's fairly commom and leads some folks to turn it off. I bought a trim level without EyeSight so I wouldn't have to put up with a demented nanny. Link to comment Share on other sites More sharing options...
ammcinnis Posted February 26, 2022 Share Posted February 26, 2022 Was on the highway and 2 times, it felt like the brake was tapped, like just a quick grab, and then it was fine. Sounds like the VDC (Vehicle Dynamics Control) system doing its thing under conditions of marginal traction (e.g. snow, ice, mud, loose sand, etc.). I wouldn't worry, unless it continues to occur on clear, dry road surfaces. You might also check your tires for adequate tread depth and proper inflation. Do you have EyeSight? If so, it probably had a hiccup - it's fairly commom and leads some folks to turn it off. Based on years of experience in our 2015 Legacy and 2016 Outback, both with EyeSight, I disagree: ... that this seems like an EyeSight "hiccup"... that such "hiccups" are common with EyeSight... that it's a good idea to disable EyeSight If you are already a good driver, you'll seldom be aware that EyeSight's even there. EyeSight is like having a second pair of eyes that never get tired, careless, or distracted. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Vancouver98STi Posted February 26, 2022 Share Posted February 26, 2022 "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Marvin, the road brought me here a month ago. PM sent. And maryjane would like to contact you. Link to comment Share on other sites More sharing options...
Brisvegas Posted February 26, 2022 Share Posted February 26, 2022 Based on years of experience in our 2015 Legacy and 2016 Outback, both with EyeSight, I disagree: ... that this seems like an EyeSight "hiccup"... that such "hiccups" are common with EyeSight... that it's a good idea to disable EyeSight If you are already a good driver, you'll seldom be aware that EyeSight's even there. EyeSight is like having a second pair of eyes that never get tired, careless, or distracted. I agree with your comments Link to comment Share on other sites More sharing options...
bcrosby51 Posted February 28, 2022 Author Share Posted February 28, 2022 Do you have EyeSight? If so, it probably had a hiccup - it's fairly commom and leads some folks to turn it off. I bought a trim level without EyeSight so I wouldn't have to put up with a demented nanny. No eyesight. I hasnt done it since. Lets hope the issue was a non issue. Thanks for the response! Link to comment Share on other sites More sharing options...
