Lgt005 Posted February 24, 2022 Share Posted February 24, 2022 (edited) Brembo brake calipers from 2014 STI. Some bolts stuck, I never got around to removing them and installing these on my car. SOLD https://images.craigslist.org/00d0d_2Z6I0wOU4K3z_0CI0t2_1200x900.jpg Edited August 3, 2022 by Lgt005 Link to comment Share on other sites More sharing options...
Lgt005 Posted March 29, 2022 Author Share Posted March 29, 2022 Bump. Link to comment Share on other sites More sharing options...
Lgt005 Posted April 10, 2022 Author Share Posted April 10, 2022 Bump Link to comment Share on other sites More sharing options...
Lgt005 Posted May 9, 2022 Author Share Posted May 9, 2022 Bump Link to comment Share on other sites More sharing options...
Lgt005 Posted May 17, 2022 Author Share Posted May 17, 2022 Price drop bump. Link to comment Share on other sites More sharing options...
All_talk Posted May 18, 2022 Share Posted May 18, 2022 What does it take to get these on a '07 GT? Is there a thread somewhere? Link to comment Share on other sites More sharing options...
ohno06gt Posted May 19, 2022 Share Posted May 19, 2022 Not sure but I think you need rotors from an 04 sti and an adapter for the rears. Link to comment Share on other sites More sharing options...
snowdrift86 Posted May 30, 2022 Share Posted May 30, 2022 what bolts are stuck? are you willing to sell just the rears? Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted June 16, 2022 Share Posted June 16, 2022 (edited) Are these still available? What bolt is stuck and where abouts are you exactly? I’m near Hagerstown. Sent from my iPhone using Tapatalk Edited June 16, 2022 by boostedgrocerygetter Link to comment Share on other sites More sharing options...
VespaGTS Posted July 15, 2022 Share Posted July 15, 2022 On 5/18/2022 at 7:03 AM, All_talk said: What does it take to get these on a '07 GT? Is there a thread somewhere? You need brake rotors and wheels that have the clearance for the calipers. Spacers can help with offset but you might need ARP studs to get it all together (also worth it). The upgrade is well worth it. We spend all this time making our cars fast without upgrading brakes, it’s kinda funny. Link to comment Share on other sites More sharing options...
Scubaboo Posted July 16, 2022 Share Posted July 16, 2022 Fronts will bolt right on with 2004 WRX STI 5x100 rotors. You may have to mod the splash shield to clear the larger diameter rotors, bending the edges of the shield outward should be ok. Rears are a bit more complicated. I dont know what adapter and rotor combo, if any, that fit 2008-up black rear Brembos to your chassis. If you do find an adapter and rotor combo, you will need to trim or remove the rear splash shields to fit it. Pre-2008 gold rears are the known entity, there are adapters for them and you will need 2004 WRX STI 5x100 rear rotors and the above clearance mods. Yes you will need wheels that fit over them also. On the 2010-up Legacies for stock wheels its known that you need at least a 17mm spacer to clear. Should be similar here I think. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted July 28, 2022 Share Posted July 28, 2022 After doing research these will not fit our rears. There is no known adaptor to make them fit. You will need the “orange brembos” from an 04-07 Sti 1 Link to comment Share on other sites More sharing options...
