need bb Posted December 12, 2021 Share Posted December 12, 2021 I noticed that my cruise control stalk is intermittent when trying to speed up. Recently it has gotten worse and most of the time pressing up on the stalk does nothing. I imagine the electrical contacts are worn out. Is the simplest fix to just get a replacement stalk? Is this difficult to remove/install? Thanks Link to comment Share on other sites More sharing options...
Pleides Posted December 12, 2021 Share Posted December 12, 2021 The stalk is extremely easy to replace. Just need to remove the torx bolts for the wheel and I think you’re good to go. This video sort of shows the process of getting it off since he replaces his steering wheel in this. Link to comment Share on other sites More sharing options...
need bb Posted December 14, 2021 Author Share Posted December 14, 2021 Awesome. Looks like time to buy a replacement stalk and give this a try. Thanks Link to comment Share on other sites More sharing options...
Pleides Posted December 14, 2021 Share Posted December 14, 2021 Best of luck! If that doesn't work, occasionally a bad neutral safety switch can cause a whole host of issues with cruise control. If you're able to turn the master cruise on and off without issue, but you're having issues with setting/resetting speed then that would be my next place to look. Link to comment Share on other sites More sharing options...
IJpie Posted December 15, 2021 Share Posted December 15, 2021 For the cruise control issue, you need to thin the washer on the neutral safety switch. Or replace it by a less thicker copper washer. The neutral switch itself works, but the plastic pin wears out. As a result, the contact is interrupted at a certain load (speed). You can compensate for this with a thinner copper washer. Simple solution that can solve your problem described with the cruise control. Link to comment Share on other sites More sharing options...
