JoeInOregon Posted December 11, 2021 Share Posted December 11, 2021 Was wonder if 08-14 wrx shrouds can fit with little to no modifications. I don't mind cutting metal if I nice fit can be achieved. I want to retain the factory snorkel and unfortunately the grim speed with the tool tray doesn't allow this Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted December 11, 2021 Share Posted December 11, 2021 I "adjusted" (cut out) the grimspeed shroud to fit with the stock snorkel, it's doable. Link to comment Share on other sites More sharing options...
JoeInOregon Posted December 11, 2021 Author Share Posted December 11, 2021 I "adjusted" (cut out) the grimspeed shroud to fit with the stock snorkel, it's doable.https://www.ebay.com/itm/Red-Perrin-Radiator-Shroud-For-2008-2014-WRX-STi-2008-2011-Impreza-/131645035670?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=711-127632-2357-0 Any idea if I could make that work. I would love to see some pics of your set up, what did you do for hood prop ? Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted December 11, 2021 Share Posted December 11, 2021 Looks like I cut off the tool tray and bent the remaining tab flat so I could fit the stock intake over it. It is a modified intake to feed cold air to the Grimmspeed box, but the mounting points by the radiator and angles are stock. I went hydraulics for the hood several years ago, will never go back to the hood prop. Release the catch, lift 3", and it raises itself The Perrin *might* fit, I see it uses the stock radiator holders still; Grimmspeed replaces them. Looks like the mounting holes are in a different place, you might be able to drill new whole to align? Link to comment Share on other sites More sharing options...
JoeInOregon Posted December 12, 2021 Author Share Posted December 12, 2021 Looks like I cut off the tool tray and bent the remaining tab flat so I could fit the stock intake over it. [ATTACH]294520[/ATTACH] [ATTACH]294521[/ATTACH] It is a modified intake to feed cold air to the Grimmspeed box, but the mounting points by the radiator and angles are stock. I went hydraulics for the hood several years ago, will never go back to the hood prop. Release the catch, lift 3", and it raises itself The Perrin *might* fit, I see it uses the stock radiator holders still; Grimmspeed replaces them. Looks like the mounting holes are in a different place, you might be able to drill new whole to align?Awesome thank you, that's is exactly what I was looking for. That doesn't look to pad will probably go this route Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
AWDFTW Posted December 12, 2021 Share Posted December 12, 2021 I just put a Subtle Solutions one on mine, it's meant to fit as is. Link to comment Share on other sites More sharing options...
madrig Posted December 14, 2021 Share Posted December 14, 2021 i know a guy that doing carbon radiator shroud ! Link to comment Share on other sites More sharing options...
NORULZleggy Posted December 15, 2021 Share Posted December 15, 2021 i know a guy that doing carbon radiator shroud ! Oh Ya!, if you can get one. They sell out in a blink of an eye. Link to comment Share on other sites More sharing options...
