DonnyJagaru Posted November 25, 2021 Share Posted November 25, 2021 As above, the CEL comes on to remind me the cat's operating temperature isn't reaching a hot enough level. It goes off when driving around town but after 15 minutes on the highway is back. This has been going on for a year now. After some research online I have some questions for those whom have been down this road: Q1: If the temp coming out of the cat is the same, or only slightly higher than going in, that confirms it's whipped, right? Q2: Is there any merit in pouring a gallon of lacquer thinner in the gas tank? Q3: Is there any harm trying? Q4: Should I stick with OEM replacement catalyst or is aftermarket okay? To say a CEL light on drives me crazy is an understatement. I will go insane if I replace everything and it's still on so trying to avoid this scenario. Car is otherwise working fine and I must have the only 2008 crowding 200,000 miles which has never had a leaking head gasket. TIA Link to comment Share on other sites More sharing options...
dgoodhue Posted November 27, 2021 Share Posted November 27, 2021 Are you getting a P420 code? Even if you are not getting that exact code, I would follow the engine diagnostic flow charts. Many time the catalytic code is a failing sensor or its an exhaust leak. Those are much more common than a failing catalytic converter. Link to comment Share on other sites More sharing options...
