mtrx Posted November 9, 2021 Share Posted November 9, 2021 Hello, i have question about automatic gearbox for b13 2.5 165. 2 weeks ago my transmission had issues with p0700 and p0768 codes. I cleaned them and all was ok for next 1500 km. I was to the dealership and they reprogrammed the transmission. My problem was when i drive the car i feel like a little kick from behind when it,'s on 4th gear at 120km/h with a little bit pressed pedal. Even when i rise my foot from acceleartion on 40-50km/h i feel a few little kicks again, and it appears when i press the pedal. So yesterday after overtaking it shows again the same codes. But this time on the dashboard i have abs and traction on with blinking cruise. Even if i clean the codes the dashlamps're on. The permanent code is p0768 and says that my shift solenoid D is the problem. On the picture is my old gearbox. I know the middle left is the solenoid for 4x4. Is it the bottom right with orange circle the solenoid i'm looking for and need to replace? Thanks. Link to comment Share on other sites More sharing options...
