proclaimation Posted November 7, 2021 Share Posted November 7, 2021 I have been having transmission problems where the transmission wouldn't engage from a complete stop. It wouldn't happen from starting on the road but it would act up down the road. I would have to put more pressure on the gas pedal to get it to engage. Once rolling down the road, it would be fine till I stopped again. When it first started, I put in half a quart of transmission fluid and it went away for 2 weeks. It did it again and I put some more fluid in and it went away for a week and a half. I plan to put cardboard underneath it to see if I have a leak but I am weary. The transmission stick shows fluid on it and I just put in a half a quart for the third time as I need to use the car tomorrow. How much fluid does this car need? Putting fluid in is helping. The stick now shows a lot of fluid on it but I don't want to overfill. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2021 Share Posted November 9, 2021 The stick should have marks on it that will show the full level. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
proclaimation Posted November 11, 2021 Author Share Posted November 11, 2021 The stick says I have transmission fluid and its bright red, not burnt. Reverse works just fine. It seems to start having slippage after driving for 5 miles so I figured that's when the transmission fluid would warm up and not be so thick. I put in Lucas Transmission Fix this morning and ran the car for 10 miles and it seems to be doing better. Only time will tell. Link to comment Share on other sites More sharing options...
