Scubaboo Posted October 26, 2021 Share Posted October 26, 2021 I am trying to check a used power window motor for a 2010 LGT. Socket has 6 pins. I am wanting know which pins to put power/ground to make the motor turn and verify it's working. Link to comment Share on other sites More sharing options...
DrD123 Posted October 27, 2021 Share Posted October 27, 2021 (edited) Here you go - it's either pins 1+4 or 3+6 depending on which side of the car it's on for the power leads (they all have 6 pins, but only the front left uses all 6, the others just use 2) Edited October 27, 2021 by DrD123 Link to comment Share on other sites More sharing options...
Scubaboo Posted October 27, 2021 Author Share Posted October 27, 2021 Thanks DrD! Sorry I am fairly new at reading wiring diagrams, are the socket pin diagrams read outside looking into the socket, or from inside the socket looking outwards? Link to comment Share on other sites More sharing options...
cww516 Posted October 27, 2021 Share Posted October 27, 2021 Looks like that depends- if the terminal numbers (or at least 1-2 of them) aren't labeled on the connector, I'd go based on wire color. Link to comment Share on other sites More sharing options...
Scubaboo Posted October 28, 2021 Author Share Posted October 28, 2021 Thanks cww, looks like its outside looking in. I only have the window regulator assembly available so I cant verify via wire colors, but will keep that in mind too. Link to comment Share on other sites More sharing options...
Scubaboo Posted March 6, 2022 Author Share Posted March 6, 2022 I finally got around to this today. I have the used driver's side motor regulator assembly in front of me. After a bit of head scratching I believe I got the pin out figured out. It's pin 3 and 6 to the motor for this socket from DrD's diagram and thanks to the additional info posted by cww516 I was able to get the orientation of these pins on the plug. I checked with a meter and there is continuity. I dont have a 12v power supply in the house though and I dont feel like going to the garage tonight to get 12v from the car to test the motor, will update further when I get to it. Link to comment Share on other sites More sharing options...
