06SubLegTx Posted September 28, 2021 Share Posted September 28, 2021 The A/C Compressor Bearing is going bad. When I took the belt of and spun the compressor with all power off, it's NOT smooth and you can feel/hear it. The Compressor still make cold air. Seems to torn on/off as needed. I'm not sure if the A/C compressor pump has sent any damage particles though the lines and in to the condenser. Questions: 1. Is there a way to tell if the compressor has started to send damaged parts/shavings etc into the lines and condenser? 2. If yes, what is it? Link to comment Share on other sites More sharing options...
Homedepotmade Posted October 4, 2021 Share Posted October 4, 2021 I just changed my compressor clutch/pulley last weekend as mine was going out along with an o-ring leak. There's a 10mm bolt, two snap rings and I use a mallet to remove the pulley. The replacement kit came with new hardware: 10mm bolt, snap rings, washer as spacers, pulley, clutch, magnet. You would have to use the provided washers to adjust gap between the pulley and clutch as I had to use 3 to get the correct clearance. There's a couple of good videos online for reference. I bought the replacement pulley through Ebay and this took about 45 min to do including taking off the pulley twice to adjust the clearance. You can see the pulley assembly on my IG account @jcspecbgsr (IG is still down btw cause big tech). To tell if your compressor is going out it will be the black oil of death as some calls it. I have an o-ring leak so I can safely remove my high and low pressure lines at the compressor. If you have refrigerant in your system, you would have to take it to an AC shop to remove it safely. This stuff is pretty nasty one your skin/environment. Once your system is empty you can unbolt the high and low pressure to see if you have any oil residue. If you do then your AC compressor is going out. You'll have to flush your entire AC lines to clean it out or you'll ruin your new compressor. Hope this helps. Link to comment Share on other sites More sharing options...
06SubLegTx Posted October 5, 2021 Author Share Posted October 5, 2021 Homedepotmade, Nice write up/details. Thank you very much for your detailed response. Link to comment Share on other sites More sharing options...
