Magnetite TXT Posted September 27, 2021 Share Posted September 27, 2021 So there was a few times I or someone else has noticed the fuel filler lid was open on my ‘21 Legacy. At first I thought I must’ve left it open. Then, sometime later, I noticed it was open again. I thought maybe someone was playing a prank or worse. (I live in NYC so…) I checked to see if there was any marks that would show tampering but there wasn’t any. I’ve forgotten about it until today when lo and behold, the lid was open again. After some troubleshooting with the key fob and the lock buttons I realized that when the car is locked all anyone would have to do is walk up to it and push in the lid. Now the lid won’t open when locked but as soon as you unlock it with either the fob or keyless entry the lid would pop open automatically. Is this an annoying glitch? Is there a way to disable this? This is the first car I’ve owned that doesn’t have a dedicated button or lever to release the fuel filler lid. Link to comment Share on other sites More sharing options...
caddygti16v Posted September 28, 2021 Share Posted September 28, 2021 (edited) Fuel theft must be rampant in your area if people push on your door that often. Never noticed it on mine I'll have to give it a try if it actually opens as soon as you unlock the car or if yours is in fact a glitch. Edit: Just tried it and mine popped open too, not sure how you would defeat this "feature" short of pulling the fuse that controls the filler door lock. Edited September 28, 2021 by caddygti16v Link to comment Share on other sites More sharing options...
Magnetite TXT Posted September 28, 2021 Author Share Posted September 28, 2021 Rampant fuel theft? Never experienced that nor did that come to mind. “Prank or worse (vandalism).” Thank you for your suggestion. Link to comment Share on other sites More sharing options...
laufu Posted September 28, 2021 Share Posted September 28, 2021 Interesting find Magnetite TXT. I just tried it on my Legacy and my car's fuel door popped open when I pressed on it once while the car was locked and then unlocking the doors. When I press on the fuel door while the car is locked, I see the fuel door open slightly, but is kept closed by the door lock. While the car is still locked and I press the fuel door again, the fuel door stays closed when I unlock the door. It seems the door lock does not disable the spring mechanism that releases the door, the lock just prevents the door from opening. Once you press the door, but spring is armed and ready to open the door. Not sure if there is a fix for this other than redesigning the spring mechanism. Link to comment Share on other sites More sharing options...
Magnetite TXT Posted September 28, 2021 Author Share Posted September 28, 2021 Exactly, laufu. The spring gets “loaded” when lid is pressed and all it takes is for you to unlock it for the spring to open the door. Probably wouldn’t matter that much if the filler lid was on the driver side where you can easily see it. Link to comment Share on other sites More sharing options...
Sansoo Ian Posted September 29, 2021 Share Posted September 29, 2021 How many people are out there pressing up on fuel doors? Link to comment Share on other sites More sharing options...
Magnetite TXT Posted September 30, 2021 Author Share Posted September 30, 2021 I don’t know. Maybe you should do some research on that subject begin a new thread. Link to comment Share on other sites More sharing options...
caddygti16v Posted September 30, 2021 Share Posted September 30, 2021 I don’t know. Maybe you should do some research on that subject begin a new thread.And yet you are the only one with that problem... Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
Magnetite TXT Posted September 30, 2021 Author Share Posted September 30, 2021 caddygti16v My last reply wasn’t for you but thanks for expressing your observation. Lol I’m done here. Link to comment Share on other sites More sharing options...
Yoda_One Posted September 30, 2021 Share Posted September 30, 2021 Be Safe. Laughing at Oneself and with Others is good for the Soul. Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
