wmmayer1973 Posted August 29, 2021 Share Posted August 29, 2021 My engine has low compression on number 2 cyl.I am planning on rebuilding my engine.I am considering going Manley rods and pistons.I am going to upgrade to a vf52 turbo and get a aftermarket oil pick up tube and upgrade to the sti oil pan.I am going to add a borla header and aftermarket in Cattes up pipe and downpipe and go magnaflow cat back.I am also going to upgrade the fuel system and go flex fuel.Any recommendations on this build would be appreciated.I would be getting a pro tune done after I’m done also. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted August 29, 2021 Share Posted August 29, 2021 Step 1: Find Tuner. Step 2: build vehicle based on their recommendations. Link to comment Share on other sites More sharing options...
Code Posted August 29, 2021 Share Posted August 29, 2021 You should expect to spend a lot. Start with a budget and work down from there. You’ll be sunrises. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2021 Share Posted August 29, 2021 Do what those guys say. I'll add do you have around $5000 to spend ? These things are not cheap. Is the body and chassis in good shape ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted August 30, 2021 Share Posted August 30, 2021 (edited) Is the body and chassis in good shape ? This. It's pretty much the determining factor in things as far as these now aged cars go. Mine, which I am currently going through the new engine process due to what appears to be a spun bearing, is in what I would call very good condition body wise. Paint isn't perfect but it isn't rusty. Do your homework and I hope you have a reliable daily. You will need it. Oh, and a bunch of money. Laugh, as you may. I thought I escaped the saga....nope. 71k on my 2009 and it needs and engine. People that know zero about cars or turbo Subarus ask me if I am ok putting a new engine in this car. I tell them it's just part of the process that is ownership. Sent from my moto z3 using Tapatalk Edited August 30, 2021 by whitexc Link to comment Share on other sites More sharing options...
dgoodhue Posted August 30, 2021 Share Posted August 30, 2021 Low compression can be due to valve clearances or 0 compression due to burnt valve. I would pull the engine and pull it apart 1st to determine the issue. Link to comment Share on other sites More sharing options...
Pleides Posted August 30, 2021 Share Posted August 30, 2021 Don't get a forged engine for a VF52. You won't be pushing anywhere near enough power that you'll instantly blow up an EJ257. 400+ WHP yes, possible 320 WHP with an IHI turbo, no. The issues with piston rings failing on the EJ257 are inherent to the engine and forged pistons don't fix the problem, if that's what you're trying to "fix" in getting a forged engine. Link to comment Share on other sites More sharing options...
Blink Posted August 31, 2021 Share Posted August 31, 2021 Very good advice so far, especially on body condition and forged internals. Costs can be subjective, but those 2 are universal truths IMO. One thing you didn't mention is what transmission you have. If stock 5MT, add upgraded clutch to your budget. My stocker held up to the VF52 for 2 years of not-abusive driving before crying uncle. Link to comment Share on other sites More sharing options...
wmmayer1973 Posted September 2, 2021 Author Share Posted September 2, 2021 It has a automatic transmission and considering adding a aftermarket valve body.The body is in excellent shape almost rust free.I have no problem spending some money on it.I am considering going with a different turbo and a external west gate.Any recommendations on a turbo?Thanks in advance. Link to comment Share on other sites More sharing options...
