VespaGTS Posted August 18, 2021 Share Posted August 18, 2021 (edited) I’ve recently added Brembo brakes to the front of my car. The fit is quite close. I will be adding ARP studs and open ended lugs due to stud length. There are so many products on the market it’s crazy. What do you guys think are good for the money? Also what material? Sent from my iPhone using Tapatalk Edited August 18, 2021 by VespaGTS Link to comment Share on other sites More sharing options...
Max Capacity Posted August 18, 2021 Share Posted August 18, 2021 (edited) You should be fine with any name brand. Back in the early 2000's we had some very lightweight lugs on the front slicks. How much money do you want to spend... ? Some eye candy for you. Edited August 18, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tehspud Posted August 18, 2021 Share Posted August 18, 2021 I used Muteki SR48s on my autox BRZ, which had longer ARP studs. They held up to 6 years of very frequent wheel swaps. Personally I stick with steel lug nuts. Link to comment Share on other sites More sharing options...
VespaGTS Posted August 19, 2021 Author Share Posted August 19, 2021 You should be fine with any name brand. Back in the early 2000's we had some very lightweight lugs on the front slicks. How much money do you want to spend... ? Some eye candy for you. [ATTACH]292916[/ATTACH] That’s a great photo Max! I went with Muteki SR48. Thanks guys! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2021 Share Posted August 19, 2021 (edited) Thanks, after posting it, I realized it was taken about this time in 2007 at Indy. We drove out for the NHRA Sport Compact Nationals, my son red lighted in the finals for his class. If he won, that would have been his second Wally. That was a fun time with my son. Edited August 19, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
