LegacyGIL Posted July 26, 2021 Share Posted July 26, 2021 My engine light, hand break and traction control light on and when I check using the scanner I got a code p0028 and I change the solenoid in the driver side and I reset the engine light and still it’s on Anyone help me to figure what is the problem actually Thanks. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Aphex28 Posted July 26, 2021 Share Posted July 26, 2021 The AVCS solenoids are actually pretty finicky. Did you replace it with a brand new one or was it a used/junkyard one? Link to comment Share on other sites More sharing options...
LegacyGIL Posted July 26, 2021 Author Share Posted July 26, 2021 I changed with SCITOO Intake and Exhaust... https://www.amazon.ca/dp/B07JBW2SG9?ref=ppx_pop_mob_ap_share Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Aphex28 Posted July 27, 2021 Share Posted July 27, 2021 hH a bit confused on what Legacy then. My apologies, I figured you had a Turbo engine. I'm not very familiar with the FB series NA engines Link to comment Share on other sites More sharing options...
subaru-tech Posted August 8, 2021 Share Posted August 8, 2021 Replace the avcs oil pressure switch not the ocv. I've been burned before by replacing the ocv. Now when I get that code I replace both Link to comment Share on other sites More sharing options...
Plastixx Posted August 8, 2021 Share Posted August 8, 2021 Replace the avcs oil pressure switch not the ocv. I've been burned before by replacing the ocv. Now when I get that code I replace both Yes, here's a good video about it. It's a bit long and drawn out (slow talker), but has some good info. Link to comment Share on other sites More sharing options...
