BrandonDyer Posted January 10, 2022 Share Posted January 10, 2022 I have the same problem. Hope it works for me too. Link to comment Share on other sites More sharing options...
silverton Posted January 10, 2022 Share Posted January 10, 2022 If your engine mounts were bad, you should also replace both of the transmission mounts. If either bushing sleeve has play in the pitch stop, chuck it. Link to comment Share on other sites More sharing options...
ilib11 Posted January 10, 2022 Author Share Posted January 10, 2022 Parts replaced: 41022AJ030 - 2 pcs, engine mounts, really broken 41022AJ112 - front engine mount, broken 41310YC001 - diff mount, just in case 41022AJ070 - trans mount, just in case http://forum.liberty.asn.au/viewtopic.php?f=18&t=36648&start=90#p452529 Link to comment Share on other sites More sharing options...
silverton Posted January 10, 2022 Share Posted January 10, 2022 the shop likely unbolted the mounts to lift the motor making it easier to replace the spark plugs. sucks they broke in the process. Link to comment Share on other sites More sharing options...
pinesol Posted January 11, 2022 Share Posted January 11, 2022 If your engine mounts were bad, you should also replace both of the transmission mounts. If either bushing sleeve has play in the pitch stop, chuck it. These cars do not have pitch stops. Link to comment Share on other sites More sharing options...
