darthqwo Posted July 5, 2021 Share Posted July 5, 2021 (edited) this is a how to for those who need to do this. this thread originated as a plea for help but now instead offers it; note some of this will seem to be asking for help but by the end is actually giving it. i know a picture is a thousand words, with the door panel taken off, there is a black connector and a white connector for the door lock and window, resp.; the white has 5 wires. for reference, the black wire on the black connector is ground, and all pins except two on the white connector can be traced to a separate pin on the main 25-pin front door connector. I have tried to put a 12v on each of the pins, but they do not operate the window Using only a 12v battery as a power source, does anyone know how to roll the window up please :lol: short pins 2 and 5; short pins 3 and 4; then apply 12v voltage on the pair of connections, and i find there is no polarity. omg thanks Edited July 5, 2021 by darthqwo i fathom it works for other subarus, but tested here is 2008 legacy Link to comment Share on other sites More sharing options...
darthqwo Posted July 5, 2021 Author Share Posted July 5, 2021 alternatively you can apply 12v directly to the two-pin connector that is inside the door that connetcs directly to the motor, and in this case there should be polarity Link to comment Share on other sites More sharing options...
