Max Capacity Posted July 2, 2021 Share Posted July 2, 2021 (edited) Yesterday, I went to drive the wagon...opened the door to be greeted by the rearview mirror hanging by its wires. The day before was the first day I didn't open the windows during the heat. I had to bond the mirror back on a few years ago, may be 2017 (?). It's been a while. This is the 4th windshield in the car. I do recall having to try a couple different adhesive kits back then. The second one was from NAPA, the Permatex Rearview Mirror Adhesive. Today I went to NAPA and bought another one of those kits, $4.27 After removing the button from the mirror, I tried a few different ways to remove the old adhesive from it. Seemed the wire brush wheel on the air tool worked well. Clamped the button in the bench vise to hold it. I did use some 240 grit cloth to get a surface on it. Also used a box cutter blade to help remove some of the old stuff. But the air tools wire brush wheel did a good job. On the windshield I tried a couple different things, IPA seemed to work well for the most of the old glue. But I finally Than I gave up and followed the directions...duh, got a single edge razor blade, that worked well. Then used the kit's "cleaner/activator cloth and continued to follow the directions. Took the car for a 20-mile test drive, mirrors still there even after doing a burnout in the driveway. I'll have to remember to open the car windows on the hotter day's. I used to do that when the car was parked at work. I also parked it near the trees at work, so it was in the shade from about 1-2PM. At home, it's full sun most of the day's now. I was just to lazy to open the windows that day because it was so hot and humid and chance of afternoon showers. I'll try and not let that happen again, the next heat wave. Edited July 2, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pleides Posted July 4, 2021 Share Posted July 4, 2021 Funny you mention this: a good friend of mine had exactly the same thing happen on his 06 Outback last week when it hit 116 here in PDX. Any word on if a windshield reflector sunshade thing would help mitigate this problem? Link to comment Share on other sites More sharing options...
SubOperator Posted July 4, 2021 Share Posted July 4, 2021 Any word on if a windshield reflector sunshade thing would help mitigate this problem? I always use them and while it still leaves the mirror mount exposed the temperature inside the cabin is much lower. With or without cracking the windows open. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Max Capacity Posted July 4, 2021 Author Share Posted July 4, 2021 I think a bigger gain for lower inside temps would be window tinting. My Spec has it, my wagon does not. But the wagon is also not the OEM windshield. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SubOperator Posted July 5, 2021 Share Posted July 5, 2021 I think a bigger gain for lower inside temps would be window tinting. My Spec has it, my wagon does not. But the wagon is also not the OEM windshield. Isn't your wagon black? that probably adds to it soaking heat. My first car was black and boy was it a heat sink. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Max Capacity Posted July 5, 2021 Author Share Posted July 5, 2021 Yes, it's black. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
