JonnyPatches Posted May 26, 2021 Share Posted May 26, 2021 I can't find the i symbol anywhere, when I hit the info switch on the steering wheel it only says check engine. Has anyone seen or know what the symbol means without me taking it to the shop. Link to comment Share on other sites More sharing options...
DougKelly20 Posted May 26, 2021 Share Posted May 26, 2021 The "i" means something requires your attention. In this case "check engine" is what provoked it. If you don't have a scanner it needs to go to the shop. Link to comment Share on other sites More sharing options...
ammcinnis Posted May 26, 2021 Share Posted May 26, 2021 When the "check engine" light is displayed, a corresponding DTC (Diagnostic Trouble Code) will usually be stored in the car's computer(s). If you don't have a code reader yourself, most auto parts stores have one and will read the DTCs for you at no charge. The next step then becomes interpreting what those DTCs mean. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
