SSpeed Posted April 14, 2021 Share Posted April 14, 2021 I have a 2009 Outback with the Harman Kardon sub in the rear cargo area. I've been searching like crazy on here and subaruoutback.org, but not a lot of detail on the Outback version of the sub, or at least I can't find it. I see a lot for the Legacy rear deck sub. When I bought the car, two door speakers were blown. I replaced them with Subaru OEMs from ebay, they work fine now. The rear sub rattles now like it's blown. Don't know if I did that with a new headunit or if it was blown before. I see a lot of threads on it's 2 ohm, but then some say 4 ohm, I see some sizes and mounting depths, but they seem to be for Legacy rear deck. Anyone have any Outback specific info before I tear into this? I guess it could be interior panel rattling, but it sounds like the sub itself. Link to comment Share on other sites More sharing options...
shandalo Posted May 2, 2021 Share Posted May 2, 2021 My 09 OBXT also had a sub rattle when I got it last year. Pulled the sub expecting to see it blown and found it in perfect working order. I ended up stuffing some fiber-fill material in the cavity and added a non-drying putty (kinda like sticky-tack) in between the speaker mounting tabs and it's mount location in the car to help isolate it from the sheet metal. The rattle went away. Sub still sounds a bit more muddy than I like but still an improvement over how it was. Link to comment Share on other sites More sharing options...
SSpeed Posted May 2, 2021 Author Share Posted May 2, 2021 Thanks for the reply, I think that's the same problem I have. I noticed someone had tried to pull the grill at one time. That seemed to be a big part of the rattle. Link to comment Share on other sites More sharing options...
shandalo Posted May 15, 2021 Share Posted May 15, 2021 Well, to add more of my experience to this, I replaced my problematic head unit with a properly functioning OEM and now the rest of the stereo sounds a bit better, except the sub which is rattling again. It sounds terribly muddy so I'm replacing it. Several past threads mention an improvement with Pioneer TS-SW2002D2 which is no longer available (don't believe vivid racing, tried it and got refunded). I searched for a couple days to find another shallow mount 2 ohm 8" sub and didn't have much luck. I finally stumbled on a lightly used TS-SW2002D2 for a fair price so I'm taking a chance on it. Should have it next week. Link to comment Share on other sites More sharing options...
