bubbagump Posted April 11, 2021 Share Posted April 11, 2021 Hello, I am looking for a bit of advice on how to proceed. It all began when I removed my turbo while doing uppipe/downpipe. Turbo was fine other than having 120k miles on it. Me being me I couldn't just put it back in, I went ahead and bought a new center cartridge, figured it would be fun to freshen up my turbo a bit. I ended up destroying my housing trying to drill out the screw holding the coolant line to the compressor housing, the one in the right of the photo below" Ok, so I need a new compressor housing. Easier said than done. I got a turbo out of a junkyard yesterday only to find out the compressor turbine ran into the compressor inlet pretty good. I am trying to get another from a user on these forums but from what he has said his might be in similar shape, waiting to hear back. I have included a pic below of the compressor turbine from the junk yard. Does anyone have experience with re-using damaged compressor housings? Is this sort of damage ok or will it noticeably affect the ability to hit boost pressures? I now regret not just putting my turbo back in as-is or ponying up and getting a fresh rebuild. By the time this is said and done I am going to have spent more money than it would have been to have just bought a rebuild. Ah well, learning is cool. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2021 Share Posted April 12, 2021 May be JmP6889928 will chime in later today... I'll be nice and not say anything else... Can you get us a picture of how your housing looks currently ? How bad could you have messed up drilling that head off ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bubbagump Posted April 12, 2021 Author Share Posted April 12, 2021 (edited) May be JmP6889928 will chime in later today... I'll be nice and not say anything else... Can you get us a picture of how your housing looks currently ? How bad could you have messed up drilling that head off ? HAH! How bad could I have messed up? About as bad as you can imagine. My drill slipped off the shaft (shank?) of the screw after the head was gone. With the pressure I was applying to the drill it went through the compressor housing like a hot knife through butter. It was a pretty instant "oh crap" moment. I'll try and get some pics when I get home. I can only imagine what you might have said if you weren't being nice. I kind of screwed this little thing up and turned it into a bigger thing .... my OCD combined with my impatience to get things back together didn't serve me well. Think I've got another housing sourced though - nothing money can't fix. By the time I get my car back together I am going to have quite the assortment of VF40 parts. Edited April 12, 2021 by bubbagump Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2021 Share Posted April 12, 2021 That's what I was thinking happened. I had no idea the housing was that thin in that area. I seem to recall sending my old vf40 parts off to JmP years ago because I had no use for them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
