TMBLKDG Posted March 26, 2021 Share Posted March 26, 2021 Ive read through a fair portion of the 6MT master swap thread and tried searching but just haven't seen anyone talking about the 6MT from the '15+ WRX. Not the STI version, the regular WRX version. Is that trans a worthy swap into something like a 4th gen 5MT? I'm assuming it must be stronger than the 5MT since the newer WRXs make more power. What kind of clutch does it use (push or pull?) Any other considerations for a swap into a 4th gen? If this has been covered already, I'm happy to follow (a) link(s) and read up on it. I apologize if this is redundant, I just couldn't find the info in the 6MT sticky or by searching. Link to comment Share on other sites More sharing options...
awfulwaffle Posted March 26, 2021 Share Posted March 26, 2021 It's a 5 speed with an extra gear stuffed in, and cable shifted because of it. Link to comment Share on other sites More sharing options...
BrandonspecB Posted March 26, 2021 Share Posted March 26, 2021 That trans is bolted to an FA20. Is the bolt pattern even the same? That's where I'd start investigating. If there isn't a lot of info than that means it's probably not worth the hassle. Link to comment Share on other sites More sharing options...
awfulwaffle Posted March 27, 2021 Share Posted March 27, 2021 ^^ I believe it is. I had one come through for a clutch a while back, bolt pattern looks very similar so would be surprised if it's slightly different. The trans looked, externally, very similar to a push style 5MT. I think having to deal with the conversion from direct linkage to cable shift in our cars would be more trouble than it's worth, since you'll still end up with a split case trans and all the limitations that presents. Back end of an EJ257 and an FA20DIT for comparison: Link to comment Share on other sites More sharing options...
BrandonspecB Posted March 27, 2021 Share Posted March 27, 2021 Yeah you're right. Same bolt pattern. Found some how tos about swapping STI 6 speeds into FA WRXs. Seems like you could do it from the link. http://https://forums.nasioc.com/forums/showthread.php?t=2892641 If it's doable it could be a fun upgrade over a 5 speed. Need to figure out final drives and driveshaft length I guess. Link to comment Share on other sites More sharing options...
TMBLKDG Posted March 29, 2021 Author Share Posted March 29, 2021 Sounds like the shift linkage would be the main problem. Seems like going from cable to direct linkage would be easier than the other way around, provided the shifter location is at least close. I was thinking that it might be a cheaper alternative and the trans should be more readily available than the STi and especially the Spec B versions. For a mildly modified legacy that isn't tracked it should be strong enough, but maybe the shifter presents enough complications to make it not worth it. Thanks for the info. I'm not the type to pioneer something like this so guess I'll write it off for now and see if there's any more info when my 5MT fails. Link to comment Share on other sites More sharing options...
ozzrulz Posted January 1, 2022 Share Posted January 1, 2022 Hi TMBLKDG, I had a 6 speed 2019 WRX transmission installed on my 06 Legacy GT and it works just fine . Minor modifications needed to be done: - Shifter assembly required some new holes drilled (see attached pictures) - The downpipe bracket will not attach on the transmission anymore - Ideally, have your car retuned to manage the 6th speed Link to comment Share on other sites More sharing options...
BoozeRS05 Posted January 1, 2022 Share Posted January 1, 2022 I have a cheap WRX 6mt nearby me and was wondering this exact thing.. I don't mind the idea of a LGT 5mt with an extra highway gear, sounds pretty great. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
