amusa Posted March 20, 2021 Share Posted March 20, 2021 (edited) My hood won’t latch. I discover this piece (near top of the photo) with the wire hanger cable connect into. I notice it’s not swivel when I release the hood cable but I can open it but does not swing back after pulling on the hood lever from inside the vehicle. Any ideals on how to resolve the issue? Edit: won’t let me upload photo (iphone12 pro). I work on it and see if I can convert it or somehow. It’s under 2MB. Edited March 20, 2021 by amusa Link to comment Share on other sites More sharing options...
stewdogg Posted March 20, 2021 Share Posted March 20, 2021 Without a pic, have you lubed the latch (under the hood) with some decent lube that's not WD-40? It's just that the WD-40 won't last very long as it's used to displace water and leave a light lube in place. Link to comment Share on other sites More sharing options...
LGTmakes3 Posted March 20, 2021 Share Posted March 20, 2021 Clean and lubricate the entire mechanism. I had problems with my latch due to rust packing between the moving parts and freezing them. Link to comment Share on other sites More sharing options...
DugsSin Posted March 20, 2021 Share Posted March 20, 2021 I hit mine with PB Blaster and white lithium grease every year. Looks like it's time again. Link to comment Share on other sites More sharing options...
amusa Posted March 20, 2021 Author Share Posted March 20, 2021 (edited) Friend lub the latch with PB (my friend sprayed the hell out of it) It’s working now. Edited March 20, 2021 by amusa Link to comment Share on other sites More sharing options...
creep_nu Posted March 22, 2021 Share Posted March 22, 2021 happened to mine too, after cleaning with some pb blaster and compressed air i lubed it up with some silicone spray. i condition all the rubber seals door/trunk/hood seals with silicone spray every fall, so i just added the latch mechanism to that list... Link to comment Share on other sites More sharing options...
amusa Posted March 24, 2021 Author Share Posted March 24, 2021 Finally it did upload, lol Link to comment Share on other sites More sharing options...
boxkita Posted March 24, 2021 Share Posted March 24, 2021 ^^^ uh, you should be lubing all moving parts at every oil change. Even says so in the manual. pb blaster and let it soak in. Keep doing it until things move freely. then use grease to coat the moving parts Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
DrD123 Posted March 25, 2021 Share Posted March 25, 2021 Keep in mind a brand new hood latch (p/n 57310AJ001) is only $46 msrp Link to comment Share on other sites More sharing options...
amusa Posted March 25, 2021 Author Share Posted March 25, 2021 I can get it for like $38 for the latch. The issue is since the whole pandemic happen. The Subaru get's rarely driven much (around 20miles in a week). The last time that hood been up was maybe almost a year ago. Link to comment Share on other sites More sharing options...
