LateToTheParty Posted March 17, 2021 Share Posted March 17, 2021 So my 95 Legacy sedan has been chugging along well, I have been daily driving it everyday since 01/2020. Last week, suddenly the brakes are pretty much non existent. It does bite, but it takes a while to stop. Also if I step on the brakes suddenly, it becomes jerky for a couple of seconds, then the brakes makes a noise and the car comes to a stop. Squeals a lot too when I am reversing and braking at the same time when parallels parking. What should I check? I did have to refill the the brake fluid reservoir 3 times since 01/2020, rotors and pads have been changed since 01/2020 also. Link to comment Share on other sites More sharing options...
Brighton96 Posted March 17, 2021 Share Posted March 17, 2021 Sounds like a caliper is seizing up. Link to comment Share on other sites More sharing options...
rdleg05 Posted March 19, 2021 Share Posted March 19, 2021 concern would be having to refill the brake fluid reservoir three times in one year. could point to a leak. have you looked at your calipers and the brake lines? Link to comment Share on other sites More sharing options...
LateToTheParty Posted March 22, 2021 Author Share Posted March 22, 2021 Just had it checked by a mechanic, air in the system, but also the ABS pump is leaking. Where can I get this part? Link to comment Share on other sites More sharing options...
Brighton96 Posted March 23, 2021 Share Posted March 23, 2021 I can pull the abs unit out of my 95 lsi if you want it Link to comment Share on other sites More sharing options...
LateToTheParty Posted March 23, 2021 Author Share Posted March 23, 2021 That would be awesome if possible. On a different note, would it be a stupid idea to just drive around with the fuse for ABS pulled/disabled? Pretty much dry pavement all around where I drive. Link to comment Share on other sites More sharing options...
boxkita Posted March 23, 2021 Share Posted March 23, 2021 if abs is leaking pulling the fuse doesn't stop the leak Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
LateToTheParty Posted March 25, 2021 Author Share Posted March 25, 2021 Got it, I meant for the brakes to actually work. I drove it a couple of blocks and its way better than with the ABS on. If I cant find the abs pump/module I will look into an ABS delete. Link to comment Share on other sites More sharing options...
boxkita Posted March 25, 2021 Share Posted March 25, 2021 vs just putting a used abs system back in? removing it altogether is an involved process . ymmv Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
