Gpruitt54 Posted March 14, 2021 Share Posted March 14, 2021 I just received the replacement hood support struts. As I attempted to install them, I discovered that the OEM hood support struts cannot be separated from the ball socket. Now that I must buy new ball sockets (sockets did not come with the struts), does anyone know the thread pitch and bolt diameter of the hood support ball socket for the 2010 Legacy? Link to comment Share on other sites More sharing options...
phillbert Posted March 14, 2021 Share Posted March 14, 2021 They should pop out of the socket. You have to pry up on the spring clip. Maybe this video will help you. Link to comment Share on other sites More sharing options...
Gpruitt54 Posted March 15, 2021 Author Share Posted March 15, 2021 They should pop out of the socket. You have to pry up on the spring clip. Maybe this video will help you. There is something completely odd about the strut on my 2010 Legacy. Looking at the condition of this strut, I am guessing this is the stock component. Here is what it looks like. Link to comment Share on other sites More sharing options...
Plastixx Posted March 15, 2021 Share Posted March 15, 2021 Similar to a friends 2014 Impreza hatch struts I helped replace. There is a metal ring in a groove that holds the ball in. It's not designed to ever come out. Out of curiosity I wanted to see how much hacking I would have to do to remove it and I basically had to destroy it with an angle grinder. Parts.subaru.com shows the OEM lift support as being the kind that you can use a flathead screwdriver to release a clip. Not sure why yours is a different style. The part number for the stud is 901390005. Link to comment Share on other sites More sharing options...
creep_nu Posted March 15, 2021 Share Posted March 15, 2021 yeah, you can't get the stud out for whatever stupid reason...thanks subaru. 901390005 is the part number, they're like $4/per, just buy some new ones. Link to comment Share on other sites More sharing options...
Gpruitt54 Posted March 17, 2021 Author Share Posted March 17, 2021 yeah, you can't get the stud out for whatever stupid reason...thanks subaru. 901390005 is the part number, they're like $4/per, just buy some new ones. Yeah. I makes little since to do what they did with the ball studs. I order a new set of 4 ball studs. I'll see how it goes and report back. On the same note. I replaced the struts for the trunk. In that location, they used standard replaceable struts. Link to comment Share on other sites More sharing options...
Gpruitt54 Posted March 18, 2021 Author Share Posted March 18, 2021 (edited) Here are the ball studs I bought and used. They were the correct size and thread pitch. Now I can use any standard strut of the correct length. Ball Studs 10mm M8 X 1.25 Thread For Automotive Lift Supports https://www.amazon.com/gp/product/B01NCV053V/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 Edited March 23, 2021 by Gpruitt54 Link to comment Share on other sites More sharing options...
dgoodhue Posted March 22, 2021 Share Posted March 22, 2021 I looked at my 2010 Legacy GT and I have that style hood strut. My 2011 and 2012 Legacy GT have the removable type hood support struts Link to comment Share on other sites More sharing options...
