SpecBroke Posted February 12, 2021 Share Posted February 12, 2021 So just under a year ago I bought a 2006 Legacy spec B. It was need some help but still in decent shape. On my way home from buying it the turbo went out. Ugh just my luck. So I decided she was going to go into immediate surgery. Long story short I got the turbo replaced and built the engine and got it tuned. Made 300hp at the wheels! After that it was time to tackle the annoying groaning noise I would hear during deceleration. Took the center differential apart as it was a likely cause. Replaced all the bearings. Put it back together and still had a noise but not as bad. So I determined it was the rear wheel bearing. When I went to remove it to my luck the rear axle nut was stuck. After heating it up and hitting it with an impact it broke the threads clean off the cv axle in the right rear. So I removed the whole rear CV axle with the wheel bearing still attached. I search online for a replacement passenger rear CV axle. I could not find one that definitively said it would work for a Spec B. I read a review on the axle I bought which was for a legacy gt and it said be careful the axle is not long enough and it pops out on its own. So I took a chance and it fit. All was well for about 6 month until today... was taking off from a stop sign merging into traffic so I was on the throttle heavy. Went to grab 2nd and when I released the clutch I heard a pop followed by a grinding noise when under acceleration. Limped it back home and jacked it up. Sure enough my passenger rear axle I had replaced a few month back popped out! So I took it apart and the teeth inside the groove for the clip at the tip of the axle were sheared off... the ones on the outside were slightly twisted. It appears to me the axle was indeed too short but was able to hang on enough until today. So I am looking around on the internet for a passenger rear spec b cv axle and can not find anything that says it fits it. When I search the Subaru part website I only see a listing for a legacy 5spd manual non spec b. Is there anyone out there that knows the part number that will fit my 06 5spd manual spec b? Link to comment Share on other sites More sharing options...
rhino6303 Posted February 12, 2021 Share Posted February 12, 2021 To my knowledge, the 06 Spec B is the same as all 5MT Legacy GT rear axles. The 6MT soec b is different. Link to comment Share on other sites More sharing options...
apexi Posted February 12, 2021 Share Posted February 12, 2021 Out of curiosity, what aftermarket brand and part number did you try? Link to comment Share on other sites More sharing options...
SpecBroke Posted February 12, 2021 Author Share Posted February 12, 2021 I was able to find it. I ordered it off of rock auto. It is a A1 cardone 667375. It says it for a 05-09 legacy outback.... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted February 15, 2021 Share Posted February 15, 2021 I would hang on to the OEM axles, aftermarket are of inferior quality. Found out after dissecting a few while building my 818. Link to comment Share on other sites More sharing options...
