Pleides Posted January 9, 2021 Share Posted January 9, 2021 (edited) Hey all, started to have a weird issue with my wagon this morning. When driving on the freeway to work, I drive mostly downhill to work and uphill back. I had cruise set at 70 MPH and, as the road started to become steep, my cruise kept disengaging. I’d re-engage it and it would disengage after a couple seconds again. When the freeway leveled out I had no issues. The master cruise stays on but the set speed keeps disengaging, only when going downhill. Also, potentially relevant but I’m uncertain: when I park my car with the nose pointed downhill and attempt to crank it to life, often the car takes a lot of extra cranking to get started. Not sure if they’re related. Car is a manual transmission. Any insight would be appreciated, thanks. Edited January 9, 2021 by Pleides Link to comment Share on other sites More sharing options...
derache123 Posted January 9, 2021 Share Posted January 9, 2021 Could it be the neutral safety switch? Seems like a common cause for CC problems (I've been having some CC issues too, although not exactly the same as yours) Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2021 Share Posted January 9, 2021 (edited) Wow, I haven't heard of this problem in about 14 years. You need to thin the washer on the neutral safety switch. I was one of the early guys to have that issue. Just remove the switch, its the upper one on the side of the 5mt, grind the washer thin and put it back on. Also this time of year, cold weather, the car may need to crank 4 or 5 times before it fires up. 3 times is normal. Edited January 9, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pleides Posted January 10, 2021 Author Share Posted January 10, 2021 OH wow! That’s perfect and exactly what I’m dealing with. Also, since I drove uphill home today, I did find that the cruise kept disengaging. Yeah I was getting like 5 extra seconds of cranking to get it to life. Neutral switch makes perfect sense. Haven’t had it happen in a week or so though. Link to comment Share on other sites More sharing options...
blackobxt Posted January 10, 2021 Share Posted January 10, 2021 Mine was doing it but only when it was hot outside or on extremely long road trips. I’ve replaced the sensor on both my outback’s and a buddies lgt. Heck of an idea to thin the washer Link to comment Share on other sites More sharing options...
KarlieBoeBoe Posted January 10, 2021 Share Posted January 10, 2021 (edited) Just out of curiosity, when you say "grind it thin", how thin is thin? I have a miraculous ability to always over-do corrections like this. I recently had to trim some kaowool from my blacksmith forge and I overdid and now it's burnt : ( Edited January 25, 2021 by KarlieBoeBoe added more background info Link to comment Share on other sites More sharing options...
blackobxt Posted January 10, 2021 Share Posted January 10, 2021 I doubt it would take much. If it works and only occasionally shuts off it means it’s just baaaarely engaged enough. So taking a hair off of it would probably be enough and a little more than that would probably be perfect Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2021 Share Posted January 10, 2021 About a third of it needs to be removed. I had to do mine twice, to get it there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
