vangloryous Posted December 16, 2020 Share Posted December 16, 2020 I've got FA 500s w/hyperco springs (8K front and rear), roll center kit, upper rear control arm camber bushings and I know I'm going to need spacers for the rear but I'm not sure how thick they should be. Are LGT upper rear control arms & bump stops required also or can I cut the existing bump stops shorter for the time being? The immediate goal is to get the car lowered a bit lower than stock LGT so not slammed. Anti roll bars, at least in the rear, will come later and possibly the whiteline adjustable rear toe & camber arms. Doing a COMPLETE OBXT to LGT part swap is unlikely but doing some of it in the future is possible. Any and all comments, suggestions and insights are VERY encouraged cuz knowing too much about lowering an OBXT isn't possible. Link to comment Share on other sites More sharing options...
boxkita Posted December 18, 2020 Share Posted December 18, 2020 not doing a obxt to lgt swap, but wanting to be lowered than a LGT? You've picked a hard road...like the one that goes off the cliff in flames. whatever. remove the body spacers. do the swap correctly. get the swaybars because you need them Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
vangloryous Posted December 26, 2020 Author Share Posted December 26, 2020 not doing a obxt to lgt swap, but wanting to be lowered than a LGT? You've picked a hard road...like the one that goes off the cliff in flames. whatever. remove the body spacers. do the swap correctly. get the swaybars because you need them Thanks for your help. Link to comment Share on other sites More sharing options...
