awfulwaffle Posted November 21, 2020 Share Posted November 21, 2020 (edited) Hey all, This is YNANSB, but a bit cheaper for someone who is willing to do a little bit of extra work. Long story short, motor is out of an 09 STI that was brought to me following a timing pulley bolt snapping and bending some valves. Pistons are OK as the failure happened at low speed pulling into a parking lot, just some light dings in the valve clearance recesses. Bores have some wear, but crosshatching is generally OK, and no asperities that can be felt with a fingernail or plastic stylus. The car had been with me a month prior for a health check and fueling upgrades. Compression tested 135 psi cold in cylinders 1 through 3, 130 in cylinder 4. Leakdown was 4-5% in cylinders 1-3, and 8% in cylinder 4. When I pulled the heads off, it was clear that they'd been off the motor before and it had been put back together hastily. Moreover, the previous owner of the car dinged up the block mating surfaces a bit, and copper sprayed the head gaskets when putting it back together. The headgaskets didn't leak, but the dings are there and pictured. The above made this a 'might as well upgrade and reduce risk' scenario for the owner, rather than just reassemble w/ reworked heads. Asking $750 OBO for a reasonably fresh shortblock with plenty of life in it. The thought is, it's a good deal for someone willing to split the block and have it decked, then re-assemble as-is (or replace #4 if it looks like a ringland is cracked and that's why it's a little lower compression/leakdown than the others). Prefer local pickup in the Detroit area and have it listed locally as well, but figured I'd post it up for LGT folks as well. I can ship freight for whatever the cost is if needed. Edited December 9, 2020 by awfulwaffle Link to comment Share on other sites More sharing options...
awfulwaffle Posted December 1, 2020 Author Share Posted December 1, 2020 Noone needs a shortblock? Link to comment Share on other sites More sharing options...
boxkita Posted December 2, 2020 Share Posted December 2, 2020 a brand new shortblock is 1800 and doesn't need maching or parts replacement. Price seems a bit high. ymmv Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
awfulwaffle Posted December 2, 2020 Author Share Posted December 2, 2020 Think so? Seems to me once sales tax on a new SB is considered, this guy would come out a little over half price all said and done. In any case, I'm open to offers. Link to comment Share on other sites More sharing options...
awfulwaffle Posted December 9, 2020 Author Share Posted December 9, 2020 Price drop/OBO bump, because I shouldn't question Boxkita's wisdom Link to comment Share on other sites More sharing options...
boxkita Posted December 11, 2020 Share Posted December 11, 2020 Price drop/OBO bump, because I shouldn't question Boxkita's wisdom Yeah, because Boxkita tracks used shortblock prices like a bloodhound. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
