SpecB_Project Posted November 13, 2020 Share Posted November 13, 2020 I got these three codes with a check engine light abs and cruise flashing, so far ive recharged the battery and change the right speed sensor but I cant get the code away for either I need some assistance Link to comment Share on other sites More sharing options...
Rojasher25 Posted November 14, 2020 Share Posted November 14, 2020 C0109 is power voltage malfunction. It comes on when power is too low or too high. Your alternator may be going bad or there may be a fault in the ground/power circuits of the abs module. C0107 is abnormal signal from front right sensor. You indicated that you already replaced the sensor which may not have been needed since it is an abnormal signal code, not an open circuit code. So that rules out contamination on the sensor. Check the magnetic encoder on the back side of the wheel bearing/hub assembly. It may be damaged/have rust or metallic particles on it which will create an abnormal signal. If the ring is damaged, the whole hub assembly will need replacement. Sent from my SM-N986U1 using Tapatalk Link to comment Share on other sites More sharing options...
blackobxt Posted November 14, 2020 Share Posted November 14, 2020 How is the car starting? Slow? Is it even cranking at all? Link to comment Share on other sites More sharing options...
SpecB_Project Posted November 15, 2020 Author Share Posted November 15, 2020 C0109 is power voltage malfunction. It comes on when power is too low or too high. Your alternator may be going bad or there may be a fault in the ground/power circuits of the abs module. C0107 is abnormal signal from front right sensor. You indicated that you already replaced the sensor which may not have been needed since it is an abnormal signal code, not an open circuit code. So that rules out contamination on the sensor. Check the magnetic encoder on the back side of the wheel bearing/hub assembly. It may be damaged/have rust or metallic particles on it which will create an abnormal signal. If the ring is damaged, the whole hub assembly will need replacement. Sent from my SM-N986U1 using Tapatalk Yeah the wheel bearing hub is rusted i bet it does need replaced as to the C0109 code I still dont understand it maybe some ground cables but im going to have to check Link to comment Share on other sites More sharing options...
SpecB_Project Posted November 15, 2020 Author Share Posted November 15, 2020 How is the car starting? Slow? Is it even cranking at all? Yea it was cranking slow but I got the battery recharged and it cranks normal now Link to comment Share on other sites More sharing options...
