SubeeOrNotSubee Posted October 8, 2020 Share Posted October 8, 2020 (edited) Where do I start? First, I love the culture and concept of Subaru, however, my experience with my 2016 2.5 Limited has been quite a ride. At this point, all I can say is Thank God I purchased the extended warranty. Here goes..... Purchased a certified 24 month lease return with 28K miles on it from the dealer that leased it out. All good there, records impeccable. Issue#1 1/23/19, Battery died. New one installed. Towing free due to Starlink subscription. Issue#2 1/30/19, Steering gear box assembly failed. Issue#3 10/31/19, Front strut, RH front and RH rear hub unit bearing, & gear box assembly (again), & power steering failed. Issue#4 11/7/19, Active Grille Shutter binding failed Issue#5, WUJ95 Recall Issue #6, Link bar stabilizers, RH F axle, Steering gear box assembly (AGAIN!!) & power steering failed. Anyone else have so many issues with their 2016? Edited October 8, 2020 by SubeeOrNotSubee Link to comment Share on other sites More sharing options...
whitexc Posted October 8, 2020 Share Posted October 8, 2020 Steering box, aka rack and pinion? There seems to be an issue with the pump maybe? Sorry to hear about all the troubles. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted October 11, 2020 Share Posted October 11, 2020 Just out of curiosity, I'm wonder what happened with "gear box assembly (again), & power steering failed.". I wonder what your symptoms were, and what parts the dealer replaced. I wonder if there was a leak, or if you had steering issues, etc. Link to comment Share on other sites More sharing options...
PATS4LIFE Posted October 11, 2020 Share Posted October 11, 2020 Not sure about 5th gens but our 6thgens legacy have electric power steering,so no pump or leaking fluid. The issue I had with my My17 steering rack is rattling noise,dealer replaced a tension spring and it worked for a while then rattle came back,then dealer replaced the whole rack assembly back in January,rattle went away till couple weeks ago I started hearing the damn rattle again,so car is going back to dealer soon:/ Link to comment Share on other sites More sharing options...
dgoodhue Posted October 11, 2020 Share Posted October 11, 2020 It seems like most of your failures are related. I would guess the steering gear failure is being misdiagnosed or the root cause of the issue has not been fixed. Link to comment Share on other sites More sharing options...
ncted Posted October 13, 2020 Share Posted October 13, 2020 Are you sure this vehicle was never in a front-end collision? Link to comment Share on other sites More sharing options...
SubeeOrNotSubee Posted October 15, 2020 Author Share Posted October 15, 2020 It would seem that way right! However, no, it was not. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
gathermewool Posted October 18, 2020 Share Posted October 18, 2020 Sounds more like they slid into something like a curb on the right side and never reported it. I wonder if how the frame and front subframe line up. What were the symptoms for each time the the rack failed? What about the hub assemblies and end links? '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
hkshooter Posted October 18, 2020 Share Posted October 18, 2020 You bought a used car, your experiences are not indicative of the reality of the majority of Subaru owners. If you want a true picture of what Subaru is as a car and car company buy a new one. I'm sorry your first one sucks. As others have indicated above something is hidden or amiss with your car. I'd ditch it and move on. Link to comment Share on other sites More sharing options...
EricS Posted October 21, 2020 Share Posted October 21, 2020 Sorry to hear of your troubles. I tend to agree that the previous owner had a very specific reason for ditching the car. I've owned 5 subarus over the past 30 years, 4 of them used. All have been great. Link to comment Share on other sites More sharing options...
kero Posted November 6, 2020 Share Posted November 6, 2020 I have had my fair share of issues with my 2016 legacy premium. Out of all my Subarus ranging from models from 2000 all the way up to the present above, it's the most greminly car I have owned. It still get the job done but I won't keep it as long as the others as I don't have confidence in it's long term reliability. 58K on it as of today. Link to comment Share on other sites More sharing options...
Grnlantern1 Posted November 6, 2020 Share Posted November 6, 2020 I have had my fair share of issues with my 2016 legacy premium. Out of all my Subarus ranging from models from 2000 all the way up to the present above, it's the most greminly car I have owned. It still get the job done but I won't keep it as long as the others as I don't have confidence in it's long term reliability. 58K on it as of today.I have been a long time Subie owner myself and wanted to step into the New Generation Legacy after seeing the Eyesite Safety commercials. I was pretty impressed so I pulled the trigger to buy one. I purchased my 3.6r New in 15' and Honesty I can't be more Happier the only problem I encountered was a bad rear wheel bearing typical subaru issue.. And of course I encountered the Transmission TSB and had to have mine replaced and the Second Transmission had a Chain Cover Leak after 47k Miles So I can say I do have concerns with the CVT Transmissions since my other Subaru's were Manual Transmissions.. Price Tag on a New CVT will make my Car a Paper Weight if it Fails again.. [emoji17][emoji17][emoji17] Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
RWebb Posted November 6, 2020 Share Posted November 6, 2020 CPO isnt as good as it sounds. Ask LunchTime Link to comment Share on other sites More sharing options...
chowser51 Posted November 6, 2020 Share Posted November 6, 2020 Sorry about your troubles. My first Subaru was the ‘15 Legacy 3.6R, no eyesight. Pretty decent car. Traded it in at 77k miles. Bought my daughter a 2020 Impreza sedan with eyesight. So far so good. Both bought new. I’m probably going to get an Ascent as my next Subaru for the 3rd row seat. Link to comment Share on other sites More sharing options...
kero Posted November 6, 2020 Share Posted November 6, 2020 I have been a long time Subie owner myself and wanted to step into the New Generation Legacy after seeing the Eyesite Safety commercials. I was pretty impressed so I pulled the trigger to buy one. I purchased my 3.6r New in 15' and Honesty I can't be more Happier the only problem I encountered was a bad rear wheel bearing typical subaru issue.. And of course I encountered the Transmission TSB and had to have mine replaced and the Second Transmission had a Chain Cover Leak after 47k Miles So I can say I do have concerns with the CVT Transmissions since my other Subaru's were Manual Transmissions.. Price Tag on a New CVT will make my Car a Paper Weight if it Fails again.. [emoji17][emoji17][emoji17] Sent from my SM-G988U using TapatalkI liked the 3.6r models but were pricey to be honest. With regards to the CVT, only time will tell, so lets just hope it lasts. I also really like the ascent but again, way outside my budget. Once I find work as furloughed from covid for over 6 months now, I will be trading for a base tacoma 4x4 or 4x2 as it suits my lifestyle better for camping and such. The 4 cylinder tacoma's are bullet proof and the engine and tranny have been produced for a long time, so not many bugs or issues one would have to deal with. Link to comment Share on other sites More sharing options...
SubeeOrNotSubee Posted November 15, 2020 Author Share Posted November 15, 2020 Sounds more like they slid into something like a curb on the right side and never reported it. I wonder if how the frame and front subframe line up. What were the symptoms for each time the the rack failed? What about the hub assemblies and end links? The symptoms were excessive play in the steering wheel each time. With the play came a knocking sound. The last replacement was an “upgraded@ part. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SubeeOrNotSubee Posted November 15, 2020 Author Share Posted November 15, 2020 You bought a used car, your experiences are not indicative of the reality of the majority of Subaru owners. If you want a true picture of what Subaru is as a car and car company buy a new one. I'm sorry your first one sucks. As others have indicated above something is hidden or amiss with your car. I'd ditch it and move on. It was a 24 month lease return that was certified from same dealer who initially leased it out. I figured that was a good way to go when buying a used car. The latest update since the last repairs is all good. No additional issues thus far. Thx. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DrD123 Posted November 20, 2020 Share Posted November 20, 2020 Wow - that sucks (as you are aware...) It definitely sounds like something is messed up that's taking the same components out again and again... you might consider calling SoA and see if they will extend the warranty on it or something like that. I imagine the electronic power steering stuff is a really expensive part, so you don't want to be stuck holding the bag if it goes when you are out of warranty! (up through the 5th gen, it was hydraulic) - other than the battery and the recall, the rest really sounds like there is something messed up in the front of the car - I think the theory of an unreported curb strike or something like that is a good one... you might consider bringing it to a body shop (or see if Subaru will do the same) to have them make some frame measurements and do an inspection... Link to comment Share on other sites More sharing options...
