joshhgraham Posted September 26, 2020 Share Posted September 26, 2020 I'm wanting to get a dyno tune for a my jdm legacy. Before the tune I am wanting to get some aftermarket parts so the tune isn't useless. I'm looking to get an intake, and I am debating between two right now: the HKS racing suction ($600), or the APEXi power intake ($220). I don't really have a clue if there would be an advantage to get the HKS, and I'm not sure if its worth to spend $400 more. Any response or advice would be awesome, thanks. Link to comment Share on other sites More sharing options...
boxkita Posted September 26, 2020 Share Posted September 26, 2020 its not a honda, so unless you have done a ton of engine work, an intake doesn't help you at all. Stock intake is to 400 awhp or higher Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted September 26, 2020 Share Posted September 26, 2020 a uppipe/downpipe will be a much better dollar spend Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Pleides Posted September 26, 2020 Share Posted September 26, 2020 Leave the intake alone. Until you get to higher power levels, the headache that an aftermarket intake causes isn't worth it and doesn't really add power. The stock intake sucks up lots of cool air because the manufacturer needed it to for a turbocharged car with emissions targets. Link to comment Share on other sites More sharing options...
Tehnation Posted September 26, 2020 Share Posted September 26, 2020 (edited) You can get a downpipe and uppipe(if you have older 4th gen with catalytic converter in uppipe) and a tune for 600 bucks...an air intake will need a tune on top of whatever your paying for it so add another 125-150. Any modifications you do to the car engine wise needs a tune otherwise you run the risk of decreasing its life, ie knock. So its better to plan accordingly to minimize the tunes you will need. So basically you can waste your money on a useless air intake to get like .5- 1hp, and at that point its probably coming from just the tune alone. Or you can get a downpipe for like 300 bucks, tune for 150, uppipe another 150(or a used one from newer car from junkyard for like 50 bucks) if you have 05-06 I believe. And you can get like what 50 extra hp... so you do the math! And if you want more hp down the line, you wont get anywhere without a downpipe, thats ALWAYS step one for the 4th gen, ALWAYS.... ALWAYS!!! Your wasting your time, our time and the tuners time by thinking about an air intake on a stock motor, without even a downpipe. Do tuners even tune a car without a downpipe??? Start here https://legacygt.com/forums/showthread.php/turboi-wiki-twist-178684.html And if all you want is the swooshing sound, just take out the stock intake airbox and remove that thingy on the bottom( its some kind of sound damper/resonator), and you will have all the swooshing you need. A performance air filter for the stock airbox will get you the same performance results for like 20 bucks versus paying 400-600 for aftermarket kit.... Edited September 26, 2020 by Tehnation Link to comment Share on other sites More sharing options...
boxkita Posted September 26, 2020 Share Posted September 26, 2020 fun things to do to your car for little or no money - https://legacygt.com/forums/showthread.php/compilation-cheap-and-free-legacy-mods-84688.html Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Tehnation Posted September 26, 2020 Share Posted September 26, 2020 jdm legacy? missed that part.... what engine is in the jdm lgt, 2.0 twin turbo? you can get a 4th gen jdm legacy in the states? Where is this guy Canada? Link to comment Share on other sites More sharing options...
Tehnation Posted September 26, 2020 Share Posted September 26, 2020 Hmmm I think we need some more info! Like other mods, location, etc. They drive on the right in Canada ... what about Australia/New Zealand do they drive on the left? Link to comment Share on other sites More sharing options...
joshhgraham Posted September 26, 2020 Author Share Posted September 26, 2020 Sorry guys, this was my first post. I'll add some mods and more information on my car. I am from Canada, and I have a 2004 JDM Subaru Legacy (technically '05 because of BL chassis code). It's an EJ20Y with a single twin scroll turbo. I have a 3" catless downpipe with a full cat back exhaust and a GFB BOV as my only mods. I also have new NHK spark plugs that I'm going to put in within this week. Thanks for all the replies, I appreciate it. You guys just saved me around $500, which is awesome. What I've gathered is that the intake is nothing more than a brand name, and the stock one should serve me well. I guess my next step is to get the tune...? Or is there mods I should be considering before hand. Another thing that I saw was that a tune cost around $150 (USD im guessing), which is very very low where I live. Best prices I could find in my province is around $800CAD for a dyno tune and around 1K for a custom tune. Apologies to Tehnation, I should have included more information Have a good day everyone! Link to comment Share on other sites More sharing options...
Tehnation Posted September 26, 2020 Share Posted September 26, 2020 (edited) I'm not so familiar with the 2.0 motors! I know for the 2.5 single turbo the intake is pointless up until a certain point. The 2.0 twin scroll is a different animal so I can't assume an intake won't be helpful! I would do some more research first. I would try nasioc, they may be better equipped for 2.0 twin scroll knowledge and information as it is a much more common mod over there, nasioc, because wrxs and 2.0 twin scroll turbos have existed a lot longer than turbo legacies in the states. So most of the information on the 4th gen on this website pertains to the 2.5 turbo usdm. I would definitely make a post on nasioc to get some insight. Edited September 26, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Max Capacity Posted September 26, 2020 Share Posted September 26, 2020 Next step I would do is, zip tie all the vacuum hoses. Make sure the MAF sensor is clean and a good clean air filter before you spend money and time data logging. with less then clean parts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
