Legacy3.0r2009 Posted September 20, 2020 Share Posted September 20, 2020 Hi , on my Legacy 3.0 2009 the climate control just turned off and I wasn’t able to turn it back on , I changed the radio for another used one and the problem stayed ... I checked the fuses they’re all good , don’t know what to check next ! Any help would be appreciated!! Does it use a different power than the radio ? The radio works and when I turn the lights on the buttons light up but the middle display doesn’t! I can’t use the heating or ac Link to comment Share on other sites More sharing options...
Max Capacity Posted September 20, 2020 Share Posted September 20, 2020 (edited) http://people.csail.mit.edu/ilh/vacation/ the service manual may be helpful. I think there's a relay in the underhood fuse box ? The relays are cheap from the dealer. I replaced both AC relays on my cars a couple years back, $6.00 each. Edited September 20, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Legacy3.0r2009 Posted September 20, 2020 Author Share Posted September 20, 2020 Ok thanks , so you think it’s the ac relay ? For that price I’d replace it Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2020 Share Posted September 21, 2020 No, I'm not sure. There are other fan relays there too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
