Eugene Onegin Posted September 14, 2020 Share Posted September 14, 2020 I have a 2017 Legacy 3.6 and the driver's door power window has stopped working it started with the window only going up half way and then going back down now it won't go up at all ,is there any TSBs on this issue ? Link to comment Share on other sites More sharing options...
chowser51 Posted September 14, 2020 Share Posted September 14, 2020 (edited) Have you tried a power window reset? Initialization of power window Initialize the power window in the following procedure to reactivate such functions. 1. Close the driver’s door. 2. Turn the ignition switch to the “ON” position. 3. Open the driver’s side window halfway by pushing down the power window switch. 4. Pull up the power window switch and close the window completely. Continue pulling up the switch for approximately 1 second after the window is closed completely. Edited September 14, 2020 by chowser51 try that Link to comment Share on other sites More sharing options...
Eugene Onegin Posted September 14, 2020 Author Share Posted September 14, 2020 Window is stuck open and I am unable to get it to move at all . Link to comment Share on other sites More sharing options...
ronemus Posted September 15, 2020 Share Posted September 15, 2020 Try disconnecting the battery to reset the BIU - it sometimes gets "confused" and doesn't respond properly. Link to comment Share on other sites More sharing options...
Eugene Onegin Posted September 16, 2020 Author Share Posted September 16, 2020 Problem solved, door switches had to be replaced on the driver's door. Link to comment Share on other sites More sharing options...
ammcinnis Posted September 16, 2020 Share Posted September 16, 2020 (edited) Problem solved, door switches had to be replaced on the driver's door. Warranty? See TSB 07-152-19R. Edited September 16, 2020 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
