Syndicate Posted September 10, 2020 Share Posted September 10, 2020 ...wow, I haven't posted here in a minute but I know 5th gen zeitgeist here won't let me down...I hope ...anyways, on my way in to work today I noticed that how much I tried, I couldn't hit my target boost (18+ psi). Boost just stopped building right around 15psi. So after work I went ahead did some logging, sure enough I could still barely hit 16psi while I was gathering the data. I took a look at the log and TD Boost Error seems to average around 3psi or so and my DAM is 1 for the entire run. I'm wondering if I can chalk this boost loss up to the heat and humidity or if there is something else going on here? I took a look around my engine bay and nothing seems to stand out (charge pipe and TMIC look good) but I can swear my car is a bit louder induction noise-wise under boost than it has been before. I still need to take a look under my car to get eyes on the diverter valve and turbo inlet though...any thoughts? Link to comment Share on other sites More sharing options...
Fabsx Posted September 11, 2020 Share Posted September 11, 2020 ...wow, I haven't posted here in a minute but I know 5th gen zeitgeist here won't let me down...I hope ...anyways, on my way in to work today I noticed that how much I tried, I couldn't hit my target boost (18+ psi). Boost just stopped building right around 15psi. So after work I went ahead did some logging, sure enough I could still barely hit 16psi while I was gathering the data. I took a look at the log and TD Boost Error seems to average around 3psi or so and my DAM is 1 for the entire run. I'm wondering if I can chalk this boost loss up to the heat and humidity or if there is something else going on here? I took a look around my engine bay and nothing seems to stand out (charge pipe and TMIC look good) but I can swear my car is a bit louder induction noise-wise under boost than it has been before. I still need to take a look under my car to get eyes on the diverter valve and turbo inlet though...any thoughts? What’s the boost(vacuum) at idle fully warmed up? Af learning for a,b,c and d? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Syndicate Posted September 11, 2020 Author Share Posted September 11, 2020 (edited) What’s the boost(vacuum) at idle fully warmed up? Af learning for a,b,c and d? At a fully warmed idle I'm seeing: Boost/Vacuum: -8.52/-8.15 AF Learning 1A: -0.60/-0.60 AF Learning 1B: -3.50/-3.50 AF Learning 1C: -1.60/-1.60 AF Learning 1D: 0.00/0.00 Edit: Attached log file09112020-Datalog.csv Edited September 11, 2020 by Syndicate Link to comment Share on other sites More sharing options...
Fabsx Posted September 11, 2020 Share Posted September 11, 2020 At a fully warmed idle I'm seeing: Boost/Vacuum: -8.52/-8.15 AF Learning 1A: -0.60/-0.60 AF Learning 1B: -3.50/-3.50 AF Learning 1C: -1.60/-1.60 AF Learning 1D: 0.00/0.00 Edit: Attached log file Should be alittle closer to -9/-10 at idle. You did have your ac off? Grab a can of break cleaner and spray all possible lines/connections and see if idles jumps. Verify tmic to throttle body coupler is sealed and not ripped if it’s stock. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Syndicate Posted September 11, 2020 Author Share Posted September 11, 2020 Should be alittle closer to -9/-10 at idle. You did have your ac off? Grab a can of break cleaner and spray all possible lines/connections and see if idles jumps. Verify tmic to throttle body coupler is sealed and not ripped if it’s stock. Sent from my iPhone using Tapatalk ...so yeah, my ac was on when I got the vacuum number. After an errand I checked and it was -12. I'll have to pick up some brake cleaner to check the old school way. Link to comment Share on other sites More sharing options...
Fabsx Posted September 11, 2020 Share Posted September 11, 2020 (edited) ...so yeah, my ac was on when I got the vacuum number. After an errand I checked and it was -12. I'll have to pick up some brake cleaner to check the old school way. -12 will be the best vacuum you can get. So I doubt there is a leak What map are you running? Ots or protune/etune? Sent from my iPhone using Tapatalk Edited September 11, 2020 by Fabsx Link to comment Share on other sites More sharing options...
Syndicate Posted September 12, 2020 Author Share Posted September 12, 2020 -12 will be the best vacuum you can get. So I doubt there is a leak What map are you running? Ots or protune/etune? Sent from my iPhone using Tapatalk ...I'm running a Stage 2 Protune. Link to comment Share on other sites More sharing options...
