pdXammo Posted September 8, 2020 Share Posted September 8, 2020 I bought this spec B assuming it was for parts but, it's turned out to be a runner and a pretty nice car. It has a salvage title but, I've decided to drive it so whatever. I am currently cleaning and replacing worn parts. We are going to re-clear the roof an the NM vehicle and I've been replacing some sun burnt rubber bits too. Deciding where to go with this but, it will be somewhat conservative. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2020 Share Posted September 8, 2020 I think you know to drive it for a while and see how it runs. Fluid changes would be the first step. How is the timing belt ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
pdXammo Posted September 9, 2020 Author Share Posted September 9, 2020 I think you know to drive it for a while and see how it runs. Fluid changes would be the first step. How is the timing belt ? Totally. I drove it to the closest Oil change place. 10 miles total. Did the air cleaner too. I'll put 1000 miles on it and do the oil early again. I wish I had saved a sample to send out but, I will next time. Link to comment Share on other sites More sharing options...
