Steeno28 Posted September 1, 2020 Share Posted September 1, 2020 Hi Team I'm brand new to this forum and am planning on doing quite a bit of research, but I had one small question. I have an 05 Legacy Limited GT with the 2.5 Turbo. It seems to run really well however, whenever I get anywhere above 5,000 rpms I get a check engine light flash and what seems to be a cutout or backfire. The check engine light doesn't stay on, however I scanned the ECU anyway and it came back with a cylinder 2 and 4 misfire. The car still runs fine, but I am looking for some perspective here. Any thoughts are appreciated. Josh Link to comment Share on other sites More sharing options...
Max Capacity Posted September 1, 2020 Share Posted September 1, 2020 First off, make sure the coil connector is tightly installed and then may be pop them off and spray some electrical contact cleaner in there. When was the last time the plugs were replaced, they are due at 60,000 miles. They should be gaped at .027-.029" if to wide you could be blowing out the spark. If your pulling the plugs to check, might as well replace them. #2 and #4 cylinders are known to have scoring or burnt valves. Good Luck 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rusty9 Posted September 1, 2020 Share Posted September 1, 2020 I had the same exact problem, replacing all 4 coil packs and plugs fixed it. My car had 160,000 miles at the time so they we're probably due for replacement... Link to comment Share on other sites More sharing options...
chato Posted September 1, 2020 Share Posted September 1, 2020 +1 on coil packs, I had the same thing. replace them all with factory parts. Link to comment Share on other sites More sharing options...
ttnio Posted September 1, 2020 Share Posted September 1, 2020 ^^^ a primary procedure to look at and perform the R&R before going further into your diagnosis. welcome Link to comment Share on other sites More sharing options...
Marvick08GT Posted September 1, 2020 Share Posted September 1, 2020 I have run these on all cars, no issues so far and great customer service. https://www.cosmoracing.com/subaru-high-power-ignition-coils/subaru-legacy-2005-2009-2-5l-turbo-ej255-set-4pcs-ignition-coils-subaru Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 2, 2020 Share Posted September 2, 2020 +1 on coil packs, I had the same thing. replace them all with factory parts. You do not have to use factory coil packs. I use intermotor from Rock Auto, and I swaer they are subaru ones with out the stamp on them. My LGT and WRX ran great with no problems. Link to comment Share on other sites More sharing options...
chato Posted September 2, 2020 Share Posted September 2, 2020 You do not have to use factory coil packs. I use intermotor from Rock Auto, and I swaer they are subaru ones with out the stamp on them. My LGT and WRX ran great with no problems. just repeating what I've heard from several tuners and what has been said on here a bunch of times. high RPM/high boost misfire could kill an engine, I'll stick with the factory parts that worked for 150k miles over saving $100 Link to comment Share on other sites More sharing options...
