05LegacyGTGa Posted March 19, 2021 Share Posted March 19, 2021 Like I asked in your other post, how much the DSS one piece ? You can put prices here, its ok. Ok I just checked your other post, $625 is a big difference. I'm happy with the drive shaft store I have. I think it was like $435. FWIW, I haven't tried to see if the locking grease tip from https://locknlube.com/collections/locknlube-grease-coupler fits yet. But it did fit on the 1986 F150 U joints to grease them. Looks like the one for the auto is $476.28. Is that grease tip needed for it? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 19, 2021 Author Share Posted March 19, 2021 No you don't need the grease tip. I'm 66y/o and have always wanted a tip that would lock onto the grease fitting. Once you try to hold the normal tip on the fitting and pump the grease gun...you'll under stand. I saw that LocknLube on one of those truck shows on TV. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Marvick08GT Posted March 19, 2021 Share Posted March 19, 2021 My factory DS lasted almost 190k. That being said, my tuner recommended I get an oem driveshaft ($500-$580) because all the aftermarket ones he has installed vibrate. I am purchasing a new subaru driveshaft for piece of mind. .02 Link to comment Share on other sites More sharing options...
Max Capacity Posted March 19, 2021 Author Share Posted March 19, 2021 My factory DS lasted almost 190k. That being said, my tuner recommended I get an oem driveshaft ($500-$580) because all the aftermarket ones he has installed vibrate. I am purchasing a new subaru driveshaft for piece of mind. .02 Hate to tell you, the OEM one I bought at 215,970 miles had to be replaced at 294,000 miles, because the rear joint was notchy. It no long moved freely. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
