GearJamr Posted June 20, 2020 Share Posted June 20, 2020 I've got a 2006 6-speed transmission that came with the shifter linkages and reverse cable not included (cut off is a more accurate term). I can pick up a JDM Spec.B shifter essentially bnib complete with linkage and reverse lockout cable. Would there be any issue in mating these two? As JDM would be right hand drive, would that affect the placement of the linkages on the trans? TIA. Link to comment Share on other sites More sharing options...
Chocoholic005 Posted June 20, 2020 Share Posted June 20, 2020 You should be fine; the linkage is the same. I believe STI models have a little different linkage in terms of length, but the Spec B should be the same. I'm running a Forester STI linkage in my legacy. Link to comment Share on other sites More sharing options...
