PhillyWilly Posted June 17, 2020 Share Posted June 17, 2020 (edited) 2007 Subaru Legacy GT Ltd Diamond Gray Metallic Mileage: 112,700 Transmission: 5 speed manual Title: Clean Lien: None Location: Philadelphia VIN: 4S3BL676X76203479 Asking Price: $6,500 email: wfriel@gmail.com phone: 215-315-3374 I love this car like a first child and am sad to part with it. However, I now have an actual first child. We have a family car (Prius :/) and I walk to work so I can't justify keeping it any longer. All the wearable items have recently been replaced. This car is an absolute blast to drive and should be good to go for a new owner. Notes -Second owner. Bought in May 2008 with 30k miles and 100% stock. -Stock up to 40k miles. Cobb Stage 1 to 50k miles. Stage 2 custom tune at around 50k miles. -All recalls performed (including new hard brake lines) -Like New Summer (5,000 miles) and Winter (8,000 miles) Tire Sets (details below) -Oil changed every 3,000-4,000 miles with Mobil 1 Full Synthetic (always by me) (Never had to add oil between changes) -All maintenance performed earlier than Subaru schedule (have records) -Received scheduled 105k mile maintenance at 98k miles: timing belt, water pump, tstat (7,000 miles early) -New clutch approx. 15,000 miles ago (Exedy Stage 1 - very happy with it!) -Only 16,000 miles on brakes -A/C recharged June 2018 -I am pretty anal about record keeping. I have an Excel schedule of work! -Please read everything before asking questions (I may have covered it) Power AVO panel filter (replaced at 97k miles) Invidia hi-flow catted downpipe 3" no name mid/y pipe w stock cans - all painted flat black Opensource custom e-tune Including Tactrix 2.0 Transmission/Driveline Exedy Stage 1 clutch (Installed at 97,601 miles) Cobb adjustable short throw shifter Cobb front and rear shifter bushings Group N Trans Mount Subaru Extra S in trans and rear (last replaced at 91,104 miles) Suspension Koni yellow shocks (Installed at approx 60,000 miles) Rallitec springs (about 1" drop) Cobb front and rear swaybars Kartboy rear endlinks Moog front endlinks Whiteline KCA-313 RCK (love this kit!) Whiteline KCA-334 offset LCA bushings Whiteline steering rack bushings Performance alignment w 1.0 degree negative camber Brakes Hawk HPS pads (installed @ 96,846 miles) Centric premium rotors (installed @ 96,846 miles) Goodridge stainless steel lines Calipers painted black Brake lines replaced under recall in Feb 2020 New brake fluid Feb 2020 Wheels/Tires Summer: Rota Tarmac 3 18x8 Hyperblack w Muteki lugs 235/40/18 Hankook Ventus V12 evo2 (Installed at 108,092 miles) Winter: OEM wheels w Michelin Xice2 205/55/17 (about 7-8,000 miles) Exterior R-rev carbon fiber grille 20% Lumar tint on all 5 windows Debadged rear trunk lid LED license plate lights Stebel magnum horn Cleared corner lights Fumoto oil pan valve (makes oil changes a breeze!) Interior Full LED kit Kenwood front speakers Replaced cabin filter at 94k miles Trunk cargo nets All weather mats (driver mat worn) Carpet mats rarely used - look new Auto dim mirror w/ Homelink Custom rear view mirror radar detector mount (radar not included but negotiable) Seats and interior in great condition for its age! Rebuild Sept 2014 (97,601 miles) ($4,000+) Replace all 8 exhaust valves, 1 new cylinder head, OEM engine gasket kit (Had low compression in cylinder #1. Leak down test showed cracked valve.) (Block and piston heads inspected and looked great!) Replace clutch with Exedy Stage 1 (#15804) Replace spark plugs - NGK2309 one step colder Replace injectors with OEM set with 20k miles, cleaned and tested by DW (Have DW test sheet) (Precautionary only bc engine was out) Install Gates timing kit w new tensioner and pulleys Install new OEM water pump and thermostat Full brake fluid flush with ATE New AVO panel filter Negatives Negatives are mostly cosmetic. While I was able to care for the interior, motor, trans, etc, not much I could do to protect the body from others. Car was involved in a couple fender benders (<20mph) Damage was cosmetic and professionally repaired Hood paint has not held up that well (see pics) Very tiny dent on roof was there when I purchased. I don't think a single friend ever noticed it. Small dent on trunk lid with unmatched paint. Who stands a bench on its side at the end of the driveway so all you can see is 2" of it! Rock chips on front end. Some marks on bumpers from terrible parkers. Radio lights come on and off. Usually ok once car warms up. Common issue. Recommend replacing. I did my best but it was subject to street parking for part of its life Edited June 17, 2020 by PhillyWilly Link to comment Share on other sites More sharing options...
PhillyWilly Posted June 17, 2020 Author Share Posted June 17, 2020 (edited) 6/14/20 @ Lemon Hill Edited June 17, 2020 by PhillyWilly Link to comment Share on other sites More sharing options...
PhillyWilly Posted June 17, 2020 Author Share Posted June 17, 2020 All pics taken 6/14/20. Engine bay pic is right side up when you click on it. Link to comment Share on other sites More sharing options...
PhillyWilly Posted June 17, 2020 Author Share Posted June 17, 2020 All pics taken 6/14/20 Link to comment Share on other sites More sharing options...
