2charlie Posted June 16, 2020 Share Posted June 16, 2020 With adaptive cruise control, my 2019 Legacy 3.6r Limited is always very far from the car ahead of mine. Is there a way to adjust this distance so it's a bit closer to the car ahead of mine? Link to comment Share on other sites More sharing options...
Soupy Posted June 16, 2020 Share Posted June 16, 2020 Legacy allows an adjustment to modulate distance from leading car ahead. After adaptive crus3 control has to selected, you will see one, two, three, or four horizontal bars in center screen. Push up or down physical switches on steering wheel to adjust following distance. Link to comment Share on other sites More sharing options...
ammcinnis Posted June 16, 2020 Share Posted June 16, 2020 Is there a way to adjust this distance ...? Have you read the EyeSight Owners Manual yet? The answer is there. The actual following distance will vary with speed, as it should. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
2charlie Posted June 17, 2020 Author Share Posted June 17, 2020 I followed this instruction but it does not seem to work. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 17, 2020 Share Posted June 17, 2020 Contact the dealer, the car is still under warranty. Those buttons should work, they do in my 2018 3.6R. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
