Thor294 Posted June 15, 2020 Share Posted June 15, 2020 1998 Subaru Legacy L Wagon Clean title VIN: 4S3BK4354W7300710 201k miles Originally a 2.2 automatic car, swapped in a JDM AVCS EJ205 engine new MLS head gaskets with ARP studs Wiring merge done by Zephyr K&N intake with tomei turbo inlet VF48 turbo ported/polished, billet wheel, and ball bearing from Hill Country Forced Induction Process West TMIC Killer B pan/pickup/windage tray Stock header with grimmspeed crossver, invidia catless up, invidia catted down into a custom 3" midpipe with Vibrant resonator and a greddy axleback. Header/up/down heat coated. AVO BPV ID1050x Injectors New OEM fpr Mishimoto Radiator/fans Group N mounts all around Walbro 255 pump with STI pickup all new shifter bushings STI front control arms and WRX SPC rear control arms 2014 STI steering rack with custom PS reservoir ABS delete with proper master cylinder/prop valve GETADOMTUNE Cyl 4 cooling mod OffTheLine Coil packs 3 AEM gauges (oil, boost, afr) in gauge pod Kartboy short throw Colorado driveshaft rebuilt 5mt shaft with new joints and refreshed carrier bearing KYB AGX shocks with Swift springs Sti front sway bar and whiteline rear sway bar It is on 16" snowflakes with medicore eagle RSA all season tires. Type-R 15" subwoofer with all new powerbass speakers in doors and alpine single din head unit Forester Compass setup (has thermometer in it too) RFRB Grille RFRB Spoiler 2 Piece headlights retrofitted with mini h1 projectors and HIDs Tinted all around (35 front drivers/pass 5 rear drivers/pass/sides and 20 liftgate) JDM clear tail lights I am sure I am missing things... now onto the bad: Usual rot on drivers side quarter panel front fenders are rusting on bottom Suspension rubs on pass side so it will need to have fenders rolled/possibly stiffer/higher springs Front bumper/rear bumper and lift gate are painted, so the car has 3 different shades of white. Runs perfect WOT, at idle/low rpm it seems to stumble. Apparently it needs aftermarket fuel rails/lines/fpr to fix this. A/C isn't fully hooked up. I have the line to go in and compressor connector just needs to be wired in. Clock spring broke so airbag light is on. I have one to put in, haven't had time or energy I'm burned out from the swap. As you can see I have thrown a lot into it. Hoping someone can take the reigns and get it running 100%. Any questions let me know. Pull: Idle/drive-by videos: Located in Central NJ (Branchburg/Whitehouse Station area) Asking $7000 OBO. Link on FB for pictures temporarily. Pictures soon to come when I'm on my PC. This photo upload sucks on mobile lol Link to comment Share on other sites More sharing options...
